Go Back    Forum > Digital Video > Video Project Help > Copy DVDs, Duplicate, Replicate
06-14-2011, 07:23 AM
manthing manthing is offline
say i have a retail dvd.
i demux the audio & video from it.
i also have an OTA (off-the-air) recording of the same show/movie/whatever.
i demux this as well.
there are some sections, from my OTA recordings that are not on the retail release.
what i want to do is cut those missing bits from my OTA recordings and "join/add" it to the retail version in the appropriate places.
what tool will allow me to do this and not re-encode the resulting video?
i don't want to erode the quality of the retail video if possible.
or if re-encoding cannot be avoided, then which tool does the least harm?
thanks.
06-15-2011, 04:52 PM
Joining video clips can only be done if the specs of the videos match.
In the case of MPEG-2 video, the specs must be "close enough" to coexist within the flagged MPEG container.
So ... run a Gspot analysis for me. See http://www.digitalfaq.com/forum/vide...-analysis.html
From that, I'll know if it's possible to merge as-is, without a re-encode.
My gut feeling says you'll have to re-encode at least one clip. Given that retail source is better for encoding abuse, it would likely be the clip that needs a re-encode. Then it would match the homemade piece, and you could merge in a good program like Womble MPEG Video Wizard.
How to Join This Forum! (PREMIUM) admin General Discussion 1 08-01-2011 08:52 PM
How to Join This Forum! (FREE) admin General Discussion 1 08-01-2011 08:53 AM
How to join this support forum admin General Discussion 2 04-08-2007 04:03 AM
Questions before you join? admin General Discussion 0 06-08-2005 02:01 AM
Procoder 2.0 encoding has macroblocking blazey Encode, Convert for discs 7 02-11-2005 11:57 PM
