Go Back    Forum > Digital Video > Video Project Help > Copy DVDs, Duplicate, Replicate
06-12-2012, 10:34 PM
Superstar Superstar is offline
For some reason, everytime I try to copy a DVD in ImgBurn, it's not working. When I open up the folder, location where the DVD files are saved, nothing is in there, however when I go to that folder, all of the DVD files show up then....but they're not showing up inside ImgBurn.
How do I fix this?
06-14-2012, 11:23 AM
Steve(MS) Steve(MS) is offline
Not sure if anyone understands what you want. What are you trying to do, burn file to disc?
If so try this, open up a small window where the file is located (outside imgburn).
Then have imgburn opened say on the right side of small window. Then drag and drop file in imgburn window.
06-16-2012, 03:11 PM
As in copy directly from one DVD onto another, using ImgBurn? If so, then that's a bad method.
Use something else --- or read ISO in ImgBurn (save to hard drive), then write ISO (from hard drive to new disc).
Burn with ImgBurn in DVDShrink, modified DVD Shrink 3.2 files [DOWNLOAD] lordsmurf Copy DVDs, Duplicate, Replicate 12 02-18-2013 01:54 PM
Dig missing? How to install Dig command for Linux in SSH kpmedia Web Hosting 0 07-25-2011 05:22 AM
In ImgBurn, should I use AWS speed, or set it to 16x instead? admin Copy DVDs, Duplicate, Replicate 0 06-11-2011 07:09 AM
Use Ycopy to skip bad/problem files when copying in Windows [DOWNLOAD] lordsmurf Computers 0 12-03-2010 01:08 PM
Tsunami DVD MPEG Pro help, audio stream missing? fortunec00kie Author, Make Menus, Slideshows, Burn 7 04-23-2006 05:42 PM
