Go Back    Forum > Digital Video > Video Project Help > Copy DVDs, Duplicate, Replicate
10-17-2013, 12:13 AM
Superstar Superstar is offline
I'm trying to copy a DVD in ImgBurn by making an image file, and everytime it gets down to about 40 seconds left, all these errors appear in the log, and it fails. I also tried ripping it with decrypter, but the same thing happened.
Is there any other options that I have?
10-17-2013, 07:37 AM
i use DVDfab for copying
10-17-2013, 07:57 AM
This probably isn't related to the copy/ripping software. It sounds like bad media is the culprit.
What's the media ID?
Try another drive. What drive are you using now?
If using Imgburn, I assume this is a homemade DVD of some kind? ie, DVD-R or DVD+R
Have you tried to copy the last file with just plain ol' Windows Explorer yet? It's NOT good to do, but sometimes that works best.
10-17-2013, 11:29 AM
I also tried with DVD Shrink and during the analyzing stage, it got down to 3 seconds when it stopped working.
how do I check the media ID? It's a Verbatim disc
The drive I used was my portable DVD burner
Yes, it's a homemade DVD-R
No, I don't know how to copy the last file with Windows Explorer...
10-22-2013, 11:03 AM
Any other suggestions for this?
10-24-2013, 12:54 AM
Windows Explorer - "My Computer" = drag and drop to copy
It may be a bad disc, or the drive has issues reading that particular disc. Try another drive.
11-20-2013, 07:06 PM
That didn't work either. Does that basically mean it's a bad disc & can't be copied?
Is there any other options at all that I can try?
Need help solving FTP errors in Dreamweaver CS5.5 Mr. Rey Web Development, Design 5 01-31-2013 12:54 AM
ATI AIW cards with shielding errors? rocko Capture, Record, Transfer 4 08-15-2012 02:49 AM
High C1 errors -- Is it the disk or the drive? cliffsloane Blank Media 3 01-15-2011 05:52 AM
Baking tapes to fix VHS errors deter Restore, Filter, Improve Quality 8 03-14-2010 02:17 PM
Voltage Errors - Pioneer DVD-r tobal2 Computers 4 08-29-2005 03:32 PM
