Go Back    Forum > Digital Video > Video Project Help > Author, Make Menus, Slideshows, Burn
01-19-2009, 08:07 AM
wheezer210 wheezer210 is offline
Hi all, been a while just kinda been out of the whole video thing for a while and just kinda got back into it.
I had to get back in the groove of things, I forgot how to use some of my favorite software...including TMPGEnc DVD Author...I am currently using ver. 3
If you use this software, be aware if you find that your hard drive space is disappearing it may well be this program.
Especially if you import DVD files to re-author your own discs.
To find out, check the following file:
C:\Documents and Settings\"user name"\My Documents\TMPGEnc DVD Author 3\dvd import
it seems that the program imports the dvd information but does not delete it automatically. I recovered 120GB of space by deleting the temp files that reside in this folder and it has been months since I used it last.
I noticed that my HDD space was getting smaller and smaller even after I had cleaned the drive, uninstalled a bunch of games and got rid of useless programs then I stumbled upon this and now I got back more than half my drive.
01-19-2009, 09:07 AM
Good find.
I had a similar issue recently, a piece of software dumping large temp and log files in the My Document subfolders.
CCleaner can help you some too, it will remove junk files it finds.
01-19-2009, 10:36 AM
padre2 padre2 is offline
You can set TDA 3.0 to dump those files into another directory - I do mine into \temp, so I can just purge them with my other programs litter.
Space camera for under $150? apparently so! admin Photo Cameras: Buying & Shooting 0 10-01-2009 04:25 AM
TMPGEnc XPress vs Plus 2.5 mlaviolette Encode, Convert for discs 1 08-09-2006 06:35 AM
TMPGEnc DVD Author troubles lordsmurf Author, Make Menus, Slideshows, Burn 4 07-15-2005 08:37 AM
TMPGEnc DVD Author Problem dminches Author, Make Menus, Slideshows, Burn 5 12-19-2004 08:04 PM
TMPGEnc DVD Author dminches Author, Make Menus, Slideshows, Burn 12 12-15-2004 12:07 AM
