Go Back    Forum > Digital Video > Video Project Help > Author, Make Menus, Slideshows, Burn
05-06-2005, 07:56 AM
Sujit Sujit is offline
I have managed to capture good quality MPEG2 files to the PC. What is the best software to use to transfer these to DVDs please? I am assuming that encodong which takes very long time is not necessary.
I can author, if needed, using the TMPGEnc Author unless one can suggest better software.
05-06-2005, 08:07 PM
Well, Ulead DVD Workshop 2 is better software, but also much more expensive, and much more complex.
"Best" is a relative term.
TDA is very basic software (limited menu abilities, for example), but depending on the usage, it may be perfect for you.
05-06-2005, 08:41 PM
Agreed. Tried it out last night and it was fast for DVD writing. I will need to consider an authoring tool for MPEG2 files and this to create DVDs.
05-06-2005, 09:12 PM
There are also some "advanced" tricks for TDA, some of my friends use them. Work-arounds to give motion/audio menus and first plays. Last I saw, this software was hovering in the $50-100 range, so the price is hard to beat.
Sometime like DVDit! PE and DVDWS2, though better software, may run $200-400 or so.
Broken mpeg2 fixer? manthing Edit Video, Audio 2 04-16-2006 07:42 AM
Problem with mpeg2 daMaddColombian Encode, Convert for discs 5 09-20-2005 11:19 PM
MPEG2 for DBS admin Videography: Cameras, TVs and Players 0 02-15-2005 10:50 AM
Editing MPEG2 video myron Encode, Convert for discs 4 12-15-2004 08:18 AM
DVDLab won’t accept MPEG2 from ATI AIW TLin2100 Author, Make Menus, Slideshows, Burn 3 11-30-2004 02:42 PM
