Go Back    Forum > Digital Video > Video Project Help > Author, Make Menus, Slideshows, Burn
06-29-2007, 01:12 PM
I've completely forgotten how to use it.
I need a multiple VTS disc. I have an MPEG-1 at 352x240, a 720x480 MPEG-2 interlaced, and a 352x480 MPEG-2 progressive. I have a still image. I want a transparent button to hover next to the text in my image. I might want menu audio.
When I look at this software, I just want to cuss. It's so poorly written, it's not even remotely easy to use. The guides already online really suck, I want something that address my specific needs above. Something for tv show collectors.
Anybody?
06-29-2007, 03:13 PM
manthing manthing is offline
multi VTS?
jeez never done this before.
transparent button is easy enough.
choose your button object from the "objects" resource tab. say you choose an arrow.
place next to menu text.
resize the arrow.
3 arrows for 3 menu texts.
now click the "link" tab on the "properties" sheet. usually on the right hand side of the screen layout.
highlight 1 of your arrows.
then in the "button visibility" combo-box choose "invisible normal".
repeat for other 2 arrows.
done.
have to look into multi VTS.
06-29-2007, 03:28 PM
red circles highlight the areas described above.
"objects" at the bottom.
"link" & "invisble normal" on the right.
i also normally remove "auto-route" and do manual route.
and then test - top leftmost highlight.
you can see that the first arrow is only a "ghost" as it has become invisible.
06-30-2007, 07:31 AM
I want to write a guide on how to use DVD-Lab Pro. It needs to pretend the person know absolutely nothing, and nothing is going to be obvious to them. So one you open the software, anything you click on or drag has to be explained.
I've not used DVD-Lab in quite a while now. I gave up on it because it was not easy, it took too long to make discs, and it didn't always do what I wanted it to. I would even get source errors on files that I know for a fact were 100% fine.
Basic requirements include: playlists, multi VTS, invisible buttons that only highlight when a menu item is being selected, and just general information on what is allowed, and how you assemble menus.
07-06-2007, 09:56 PM
wayshway wayshway is offline
Send a message via AIM to wayshway
My wife tried using this and just about pulled her hair out.
05-20-2011, 07:00 AM
i've attached a rough & ready guide.
hope it helps.
dlp is not all that bad.
just have to get the hang of it.
not sure if its the best authoring tool out there.
it does everything i want.
and i find it quick & easy to use.
plus, on my system, it is very stable.
whereas i've had lots of instability issues with dwsp.
dlp may not be the most intuitive authoring app out there, but believe me, once you get to know it, its easy-peasy.
i've been using it for a good decade or so and have never had a problem with it.
ok, if you do have issues with dlp, throw up a question or two and i'll do my best to answer.
05-20-2011, 07:02 AM
oops, forgot to attach the doc. here it is...
TPMGenc DVD Author 1.6 - How to use this program ? MagnificentMarcus Author, Make Menus, Slideshows, Burn 8 11-28-2006 12:03 AM
Tsunami DVD Author Pro - New Version allaboutduncan Author, Make Menus, Slideshows, Burn 6 08-30-2005 02:53 PM
TMPGEnc DVD Author troubles lordsmurf Author, Make Menus, Slideshows, Burn 4 07-15-2005 08:37 AM
TMPGEnc DVD Author Problem dminches Author, Make Menus, Slideshows, Burn 5 12-19-2004 08:04 PM
TMPGEnc DVD Author dminches Author, Make Menus, Slideshows, Burn 12 12-15-2004 12:07 AM
