10-20-2023, 10:03 AM
DigiTime12 DigiTime12 is offline
I’m trying to build a DIY tape rewinder/cleaner and I have it largely figured out but am curious when it comes to rewind/fast forward. I have 2 motors but don’t know if a VCR uses one motor to pull the tape to the right when fast forwarding and then uses the other to pull to the left in rewind and therefore only uses a single motor or does it actually use both motors together when fast forward/rewinding? Does anyone know the answer to this?
10-21-2023, 08:18 AM
It uses the capstan motor for both rewinding and fast forwarding by switching gears, Some high end VHS and Beta machines use direct drive hub motors, one motor for each hub.
10-22-2023, 01:51 AM
timtape timtape is online now
Some VCR's use one central motor for both forward and reverse but the motor can only wind one reel at a time, not both at once.
10-26-2023, 03:46 PM
ofesad ofesad is offline
Most rewinders just use a single motor. They are pretty cheap pieces of hardware. I have several.
However, they use a less powerfull motor than vhs decks.
Keep that in mind, since using a vhs deck motor you could cut or broke a tape. I have.
My recommendation, if you want a device for cleaning and rewind tapes: use a Panasonic J series deck.
J40, J45, J46, J48, there are several models (it varies deppending on continent/zone).
The J mechanism is different from regular decks: when FF or Rewinding, the tape IS NOT on the head. It takes it away from it to prevent wear. This allows you to rewind and clean the tape in the process.
I recommend having one just for this purpose.
Ofesad
fast forward, motor, rewind, vcr
Sony CCD-TRV328 camcorder cut my Hi8 tape on rewind? bluegrassdj Video Hardware Repair 27 04-28-2021 09:07 PM
Do physical tape testers exist? aka soft wind/rewind? nicholasserra General Discussion 2 12-07-2019 01:37 PM
Sony SVO-9600 tape drive motors runs slow Eddie_Tor Video Hardware Repair 11 05-15-2016 11:50 AM
JVC BR-8600U won't play tape, fast forward, rewind? Dead Christmas Video Hardware Repair 2 05-07-2016 07:31 AM
