11-06-2024, 05:24 PM
knucklegee knucklegee is offline
Hello,
Im relatively new to Hi8 videography and have been using a canon UC7500 with great results. However, recently a bit of sand may have gotten in, and I do believe I have got most of it out, and that not much got in in the first place. Nevertheless, since then it hasnt been working at all. When I try and record/playback to digitise it starts flashing an “eject” on the viewfinder. When ejected, the tape has been taken out of the casette. Is there any way to fix this?
Thanks!
11-06-2024, 06:32 PM
dpalomaki dpalomaki is online now
BTW, I believe the UC7500 is Video8 only, not Hi8 capable.
Probably could be fixed, but almost certainly not something that can be resolved through web site posts. Even a wee bit of sand or grit can play havoc with the tape transport internals; anything from friction material to mode detection switches. It might be possible to clean it out with a combination of gentile applications of vacuum and compressed air, but that could just as likely make it worse. It will probably require a qualified technician to disassemble and service the unit. Given that it came out in around 1998 finding parts and/or service would be problematic, and a skilled technician would be costly.
You may well be better off seeking a working Hi8 (for s-video output) or a Video8 capable D8 camcorder.
11-06-2024, 06:35 PM
timtape timtape is offline
dpalomaki basically said it ahead of me.
These camcorders are precision, complex mechanical devices. They need care. They need maintenance. One small grain of sand can become caught between tiny gears inside and jam them up. Best to prevent dirt and sand entering in the first place. If you want to use obsolete recording formats today, before using them it's best to study up on them. Have you read the Owner's Manual where it talks about care of the equipment?
8mm, hi8, videography
Canon GL1 in 2021? Leighgion Videography: Cameras, TVs and Players 8 08-19-2021 07:55 AM
Editing interlaced footage without destroying fields? JamieStar99 Edit Video, Audio 3 02-23-2018 03:17 PM
New lens for the Canon EOS 700D? EricC Photo Cameras: Buying & Shooting 1 06-17-2015 08:03 AM
Which camera should I buy - Canon T2i or Canon T3i ? jonny_221 Photo Cameras: Buying & Shooting 7 03-22-2011 12:04 PM
Best third-party 70-200 lens for Canon? admin Photo Cameras: Buying & Shooting 1 02-27-2009 12:41 PM
