12-28-2014, 11:45 PM
zsl123 zsl123 is offline
Hi, I just got a JVC HR-S9500U for the holidays for converting my tapes (I'm using a Toshiba DR-430 DVD recorder to cap them). I have everything hooked up including the S-Video cable as well as the composite cables. I can't see my DVD recorder menu when I have the S-Video cable plugged in, but when I unplug it everything is there.
My main concern is that it's only capturing what the composite cables are putting out rather than the S-Video one. Is it, and if it is, is there any way to fix it? Sorry if I sound like a total noob, I'm newer to tape archiving.
Thanks!
01-01-2015, 09:41 PM
There is no reason to connect the composite output and S-Video output of the VCR to the DVD recorder at the same time.
Connect the S-Video output and select the corresponding line input of the DVD recorder using its remote/menu system.
01-03-2015, 07:33 AM
That should be a good VCR (if NTSC, not PAL), and it's a decent DVD recorder. It won't make the tapes better, but it also won't make them worse like most DVD recorder.
Don't connect both composite and s-video. That's probably all it is. And yes, use the s-video.
You may find that you need a TBC between the VCR and the DVD recorder.
jvc, vcr, vhs
Looking for S-video breakout cable (to RCA) eonmc2 Marketplace 1 09-29-2013 03:12 PM
S-Video cable or is composite ok? JT_too Capture, Record, Transfer 12 03-04-2013 07:24 AM
VGA to S-Video and/or composite video in one handy cable! *Bix* Tech Myths, Misinformation 1 03-04-2011 06:14 AM
JVC HR-S9500u vs HR-S9800u (9900,9911) + Do I need to buy an external TBC? lordsmurf Restore, Filter, Improve Quality 0 09-27-2010 05:25 PM
How to split cable TV and cable internet coax for two rooms ? stoogedog Computers 6 12-05-2006 06:15 AM
