03-28-2009, 09:16 PM
Altek Altek is offline
I noticed two types of Verbatim DVD+R DL media. I saw Verbatim 2.4x-6x and 8x-10x. Which speed Verbatim DVD+R DL media should I buy? At what speed should I burn? I use ImgBurn.
03-29-2009, 03:35 AM
There is really no definitive answer here. Much of this depends on the DVD burner in use.
For example, I mostly use a Pioneer 111 drive for burning DVD+R DL media. In this drive I primarily use the 2.4x-6x discs, Verbatim made in Singapore, and burn at either 2.4x for master/archival discs, or 4x for duplicates for others. The 6x burns are always rotten quality, if the burn even succeeds. The 4x burn speed has a higher coaster count too, than the 2.4x speed, maybe 1 in 20 at 4x, instead of 1 in 50 at 2.4x.
Ideally, I'd think a 8x DVD+R DL would work great at a 4x or 6x burn speed, but whether that disc can be burned that "low" depends on the burner and firmware.
The most I can do here is share what I do.
Software can read and burn better than others? wheezer210 Copy DVDs, Duplicate, Replicate 1 11-07-2006 12:28 PM
How do i download so i can burn to disc stoogedog Encode, Convert for streaming 5 10-11-2006 05:27 AM
Types of Copyprotection Tom_n_Jonna Restore, Filter, Improve Quality 2 01-19-2006 08:23 AM
Bad burn with Fuji Taiyo Yuden, what could have gone wrong? MagnificentMarcus Blank Media 18 09-14-2005 06:42 AM
How to burn extras onto a DVD markatisu Author, Make Menus, Slideshows, Burn 0 06-02-2005 10:00 PM
