04-11-2010, 10:08 AM
continued from email...
Remember to ask all tech questions in the forum!
Could you please tell me what DVD media is best for the LITE-ON DVDRW SHM-165H6S?
Your earlier recommendation of media for another drive worked very well, thanks.
Frank
The LiteOn DVD burners are decent burners, and there's really not any media it specifically does or does not like, in terms of being abnormal. It's a normal drive, so the normal good/bad list of media still applies.
I would suggest Verbatim DVD+R ($23 for 100-pack) or Taiyo Yuden DVD-R ($25 for 100-pack). Free shipping.
More information on quality blank DVD discs at http://www.digitalFAQ.com/reviews/dvd-media.htm
More information on where to buy good blank DVDs at http://www.digitalFAQ.com/reviews/buy-blank-discs.htm
Hope that helps, and happy burning to you!
04-14-2010, 03:09 AM
khriszseo khriszseo is offline
I would also recommend Verbatim DVD have read on some forums that it is best on LiteOn DVD burners
Lite-On iHAS224 in Windows 7 KnightRider56 Computers 1 03-11-2010 04:03 AM
Lite-On 16x DVD burner Cajunasian25 Blank Media 2 12-09-2006 09:35 AM
Lite-On DL DVD Recorder at Best Buy $89 markatisu Capture, Record, Transfer 1 11-25-2006 02:43 AM
Lite-On LVW-5115GHC d.smyth Capture, Record, Transfer 8 09-29-2006 07:55 PM
Lite-On LVW5002 d.smyth Capture, Record, Transfer 3 07-22-2005 10:18 AM
