04-13-2009, 12:46 AM
The following method has been known to work for recovering the video from:
  • DVDs that crashed while being finalized; This probably means you were using a low-grade/low-quality DVD blank
  • DVDs can no longer be finalized for whatever reason; (1) You may not own the recorder anymore, or (2) The recorder is now broken. Please note that is is ALWAYS PREFERABLE to find another machine is the same or similar make/model, and finalize on that unit. Sometime units from "other brands" can finalize discs too, such as how many modern Panasonic and JVC units can often interchangeably finalized media okay.
The following free software is needed for this process:
To recover your video, perform the following steps.
  1. Open ISOBuster
  2. Select DVD drive (NOTE: If you can see "Track 01" in the left hand pane, it can recover at least some of your data.)
  3. Open Options menu
  4. Select "Image File"
  5. Select "ISO/BIN/TAO" Tab
  6. Uncheck both boxes
  7. Close dialog window
  8. Right click on "Track 01" in left-hand pane
  9. Select "Extract Track 01"
  10. Select "Extract User Data (*.tao, *.iso, *.wav)"
  11. Choose where you want to save the data. (It will copy everything it can find as one big .tao file)
  12. Use VOBEdit to open and then demultiplex the .tao file
  13. Edit the demultiplexed video using your favorite MPEG editor, such as Womble MPEG Video Wizard.
The following users thank lordsmurf for this useful post: Darby_Crash (01-29-2022), mlongue1 (12-28-2010), pimpolho (11-26-2020)
12-08-2009, 05:20 AM
shah4090 shah4090 is offline
tnk proooooooooooooooooooooo
The following users thank shah4090 for this useful post: mlongue1 (12-28-2010)
Recover Data From a Bad Disc, Restore Damaged CD/DVD [GUIDE] admin Blank Media 6 02-11-2011 09:01 PM
Create Motion Menus with Adobe Premiere [QUICK GUIDE] lordsmurf Author, Make Menus, Slideshows, Burn 4 04-01-2009 07:45 AM
Where to Find DVD Menu Artwork? [QUICK GUIDE] lordsmurf Author, Make Menus, Slideshows, Burn 3 02-21-2008 03:06 AM
How to salvage unfinalized JVC-recorded DVDs Tom_n_Jonna Capture, Record, Transfer 6 02-27-2006 06:43 AM
Trying to add video to unfinalized disc mlaviolette Author, Make Menus, Slideshows, Burn 3 12-01-2004 04:37 AM
