07-08-2010, 01:42 PM
The following Photoshop PSD documents and JPEG images are blank templates for creating your own CD cases.
NOTE: We also have blank DVD case templates! See http://www.digitalfaq.com/forum/medi...e-artwork.html
Instructions:
To download the covers, simply register for the forum (it's free!), and then login and download the templates below. That's it. Your e-mail address is not sold (no spam!), and you'll be joining a community dedicated to digital media topics -- especially when it comes to creating high quality discs!
Notes:
  • White + Black + Transparent Canvas: The PSD files come with transparent, black and a white backgrounds. The JPEGs have a black background. But a quick swipe of a large-pixel paintbrush can easily change it.
  • Guides and Rulers: The blue guides are preset, marking the spine area, so be sure the rulers and guides are enabled in Photoshop, as covered in the Making Cases with Photoshop Guide.
  • Saving Artwork: When you save a CD case, it is suggested to keep a master PSD, for later updates or edits. For the version that is printed or shared, a TIFF is preferable, but a JPEG is acceptable if saved at maximum compression.
  • Adjust As Needed: Although not as bad as DVD cases, remember that CD cases can also vary from manufacturer to manufacturer, by a few millimeters. You may or may not need to adjust these templates by a tiny fraction, plus or minus, to fit your exact cases. You may want to print a test page before committing to a huge print job, and cut it out to see how well it fits.
Guides, Help and Tips:
For help on how to edit these templates, and some basics on Photoshop cover creation, see the guides below. Although these were geared towards DVD case creation, the same techniques would be used for created CD cases:
also worth checking out is:
Stay Updated:
Simply Like Us on Facebook and/or Follow Us on Twitter to get news on when new cases are added, as well as find out about great deals on empty CD/DVD cases and blank discs. In the near future, we'll also be adding more cases, including a number of professionally pre-designed cases that will be easy to use in Photoshop! You won't want to miss out on those.
and the Downloads...
The PSD and JPEG files are inside the attached ZIP or RAR archives. If you're not sure what these files are, read the instructions on how to use RAR and ZIP files.
06-21-2011, 01:40 PM
dyfan dyfan is offline
Is it possible to modify (i.e., narrow) a DFAQ template? (I have slimmer/thinner poly case I'd like to use)...
Thanks!
06-22-2011, 03:46 PM
With Photoshop, you can do almost anything.
In terms of template creation, that's something we can only do if we have proper measurements of the dimensions.
06-22-2011, 03:51 PM
May I submit a sample? With results posted here for all to utilize, like last time?
06-22-2011, 05:05 PM
Absolutely.
DVD Case Artwork Blank Templates for Photoshop [DOWNLOADS] admin Blank Media 19 10-10-2010 05:33 PM
Please make some DVD and CD poly case templates admin Blank Media 3 07-07-2010 11:22 PM
Spindle vs. Amaray case (vs. CD jewel case?) Reading Bug Blank Media 5 05-12-2009 07:37 PM
More DVD case templates for download wayshway Blank Media 2 03-14-2009 06:15 PM
Where to Find DVD Menu Artwork? [QUICK GUIDE] lordsmurf Author, Make Menus, Slideshows, Burn 3 02-21-2008 03:06 AM
