11-07-2011, 07:38 PM
vampat vampat is offline
Hi,
I want to know if the bdr Panasonic are good media.
are they comparable to verbatim (Mits Kagaku)?
I always purchase verbatim but now I found that the MID code of my bluray is CMC magnetics...
So, the panasonic are made in japan, are they good media for archival? are they considered to be in the first class quality bluray?
if not, which bdr are the best?
and i don't understand why the panasonic are not in the list of the quality media by categorie....?
Thank you in advance
11-07-2011, 07:55 PM
Ignoring any issues of firmware compatibility (i.e., what model of drive do you have?), then these are good discs: YES.
Media ID for 4x 50GB Panasonic BD-R = MEI-T02-001
MEI = Matsushita Electric Industrial
Matsushita = Panasonic + JVC parent corporation, which is why you find them in Panasonic branded packages.
Amazon has a 50-pack for $350: http://www.amazon.com/gp/product/B00...SIN=B00406VZ40
How does this price compare to what you've seen?
A new review dedicated to Blu-ray quality (BD-R, BD-RE) is currently being written, based on a year worth of testing. More guides are being written to address complementary concepts of longevity, burning, authoring, etc. It will be completed by the end of February, though I hope to have it completed much quicker than that. Just have to be realistic about timeframes, given all the projects and other guides/editorials currently in the queue. You should see some major changes to our media articles soon. I was penning outlines this afternoon, going over the new layout of information.
11-07-2011, 08:03 PM
Thank you for your reply
my burner is a Pionner BDR-206
So, can we say that this bdr are in the 1er class media? If JVC are, i suppose that panasonic are too...
if you have tooà choose between panasonic-jvc vs Verbatim ( mits kagaku, not CMC), witch one is the best with pionner burner?
thank you very much!!
11-07-2011, 08:12 PM
These discs should work perfectly in your Pioneer BDR-206 drive.
JVC's optical media division is owned by Taiyo Yuden, not Matshusita. The "JVC" brand name is split among a number of owners in various product industries. It's no longer a single company. So no, it's not safe to assume JVC is using MEI media.
MEI, Mitsubishi and Taiyo Yuden are all safely in the 1st Class Blu-ray (BD-R, BD-RE) status, yes.
TDK's Japanese media are there, too.
How does this price compare to what you've seen? I looked at popular stores like Meritline and Supermediastore, and they're not even offering these discs currently. (And what they do have in stock is more costly -- Verbatim discs.)
Panasonic can finalize JVC discs lordsmurf Capture, Record, Transfer 13 07-26-2013 02:52 PM
Kodak DVDR quality? Kodak discs any good? lordsmurf Blank Media 0 11-04-2011 09:39 AM
Are these Verbatim discs the good ones? (Good prices for blank DVDs!) admin Blank Media 0 08-15-2011 10:08 AM
Verbatim DVD+R DL 2.4x blank discs at Best Buy (made in Singapore) Tranzor Blank Media 4 06-02-2011 12:59 AM
Micro 4/3rds cameras by Panasonic as good as Nikon DSLR's? As good as D7000? Sossity Photo Cameras: Buying & Shooting 1 10-28-2010 10:47 PM
