08-19-2013, 04:01 AM
rusdi rusdi is offline
Hi Everyone.
want to ask about audio L/R for Karaoke.
i'm new useing TAW4 and i'm trying to make a dvd karaoke with TAW4.
and i having a problem with left and right audio.
when i played in stimulation everythings ok.
but when i burn it, i can't switch L/R audio through dvd player remote. i have to back to menu screen and choose the audio 1 or 2.
then so far my suggestion is, i dont have stream audio channel. all i got is audio track and it make me can't switch the audio L/R from dvd player remote.
anyone can help me ?
i attach some picture
__________
EDIT:
i just try to add the channel audio, and check it again from VLC.
but when i burn it, still no L/R in dvd player
help me someone....
08-19-2013, 10:24 AM
Are you sure the DVD player allow left-only or right-only audio? Most do not.
08-19-2013, 01:37 PM
thanks for the replay KPmedia.
in dvd player i have to switch the sound through dvd menu.
can't switch it from L/R remote dvd player
08-24-2013, 06:54 PM
I've never seen DVD authoring software that instructed the video to play only L or R channels in the menu. I've only seen players that physically can select the audio channels.
It usually needs to be multi-track authored, not L and R separate.
If I were you, I'd use TMPGEnc Authoring Works, and then do a two-channel audio video. For one, that's going to be complaint to the DVD specs, and work on all players.
08-25-2013, 01:57 AM
in karaoke vcd we can switch the audio (on/off the voice) channel L/R button through remote. right ?
2 days ago i burn karaoke dvd, and to on/off the voice i have to press language button.
can i make my karaoke dvd works like vcd ?
Thx
07-27-2014, 04:52 AM
The multi-language DVD authoring idea is a good one.
It may use VCD -- you'll just have to burn one and test it. Some DVD players play VCD, some do not.
This was an unanswered question or unresolved issue found during a site audit. It's hard to have an FAQ when the answers are missing, or final outcomes are unknown. At The Digital FAQ support forum, questions are never intentionally ignored, and may have been missed due to a forum glitch or human error. More details on the audit. (In some cases, threads have been edited/updated with newer information.)
Burning Software For Mac Chala Blank Media 4 08-01-2010 02:33 AM
Problems burning Pepeart Blank Media 17 08-25-2005 06:54 PM
DVD+R Burning issue - disc stops burning halfway through staypuftman2004 Copy DVDs, Duplicate, Replicate 3 07-23-2005 05:35 PM
DVD Burning Errors, Cyclic Redundancy Check and burning freezes rmehta2 Copy DVDs, Duplicate, Replicate 7 07-13-2005 12:34 PM
