11-22-2022, 08:57 PM
MrPete MrPete is offline
Once I learned fully proper alignment***, the K Mechanism on my AG-5710 works nicely in manual (turn the gear with my fingers) mode.
I only have three issues. One I am pretty sure I understand. The other two, not so much:
1) Once I've got a tape in play mode, when I go to eject, the arms withdraw but the tape takes forever to retract. I assume that's an issue of worn brakes in some way. After #2 and #3 are solved I can go check that.
2) When inserting a tape (junk tape for now!), the cartridge does not go all the way down by itself. I must press on it to get the last 1/4" of drop. It doesn't resist me... just doesn't go down. WHY?
3) When ejecting, as noted in #1 it takes a while for the tape to fully retract. But then: it NEVER ejects. In fact the front lid hasn't dropped. (Not sure exactly when that happens. Should it drop before the cartridge begins to rise up?) So now I have a tape stuck in the VCR. Thoughts?
Keys to proper alignment of Panasonic K-Mech:
  • leave the motor off the unit until fully aligned AND the cartridge mechanism is placed.
  • align everything until the markers are correct and mode switch as well
  • THEN tweak off a bit to get the side cartridge-load-gear into its position. It has a large bump that meshes into a hole on the side of the main gear. Mode switch turns about 20-30 degrees. Flip the mechanism over: plenty of examples showing exactly which dot on the gear must point sideways.
  • that gear gap meshes with the SECOND cog on the cartridge mechanism. NOT the first (some documents say the first!)
  • NOW install the cartridge loader (which will be in fully disengaged mode to accomplish the proper mesh
  • TEST and ensure you can fully load/unload manually. Rework until that works.
  • NOW install the motor and the rest.
11-23-2022, 06:41 AM
https://www.digitalfaq.com/forum/vcr...e-loading.html
discusses a couple possibilities for load/unload problems.
11-23-2022, 10:14 AM
Yes... I mentioned his video in an earlier post. VERY helpful. But none of those were my issue!
11-23-2022, 10:20 AM
HOORAY!!!! What a great feeling: my first VCR repair. MANY thanks to those who came before, and those who helped with responses to my many questions.
The final issue was quite subtle: on the right side carrier for the cassette holder, a small spring was dangling. Found no photos but guessed the location (the nearest plastic post). That was it.
Symptoms: failing to eject, failing to fully load.
Cause: a tiny disconnected spring on the cassette holder.
While I was at it, I cut open and cleaned the mode switch as well. Buttoned it up, and all functions are working. Video checks later. Time to prep for Thanksgiving and family showing up
Panasonic NV-9600 will not eject? Dead Christmas Video Hardware Repair 7 05-02-2022 04:10 PM
JVC HR-6955 S-VHS won't eject tape? Rubycon Video Hardware Repair 2 12-20-2021 03:36 AM
Anything close to Ulead DVDWS2 in Windows 7+? (LS?) rbatty Author, Make Menus, Slideshows, Burn 4 01-03-2016 02:17 PM
Konica Minolta 5440DL toner cartridge replacement manthing Photo Processing, Scanning & Printing 5 04-21-2013 04:52 PM
Programs begin to open -- but then close ? ninjastriker Computers 10 05-22-2006 08:48 AM
