03-20-2020, 04:21 AM
Aerith Aerith is offline
I was going through some old boxes trying to see if I had the parts to put together a capture PC and I found this Asus AGP-V6800 graphics card. It was pretty fancy and came with VR googles. More importantly it also has S-Video IN, S-Video OUT, and Composite OUT.
I remember playing with this card and a VCR way back around 2001 but I can't remember much more than that. Does anyone know if this is a good capture card?
Sorry! It looked fine from my computer. Let's see if this works...
03-20-2020, 05:27 AM
Attach the image to the post, not Imgur. Need to see it, not sure. Though probably not.
-- updated --
Wow, I remember those. It's a rebadged GeForce card. It functioned, but was not a great card that I can remember. It's been 15+ years since I saw a capture from one. I vaguely remember the card being even worse than an ATI AIW to install, more like a Matrox or Canopus internal. I thought it was a Philips chip for capturing, but did not see one in your image.
And that card needs a cleaning!
The following users thank lordsmurf for this useful post: Aerith (03-20-2020)
03-20-2020, 07:53 AM
Thank you for the reply!
There is a Phillips brand chip on it. It's the one next to the upper S-Video connector. You probably can't see it though because of the low-res image. The chip is the SAA7113H. The datasheet calls it a "9-bit video input processor".
Is Asus EeeBook X205TA good for daily use? tarun_bazooka Digital Devices 4 09-28-2015 05:51 AM
Will my LCD monitor be good enough for video work? (Asus VH242H) rappy Project Planning, Workflows 1 04-24-2012 01:11 PM
Philips SAA7314 chip, good capture card for the DVD look kpmedia Capture, Record, Transfer 10 12-06-2011 10:20 PM
A Good TV Tuner Card?? Konfusion Capture, Record, Transfer 7 09-19-2007 10:18 AM
