Go Back    Forum > Digital Video > Video Project Help > Encode, Convert for streaming
12-21-2020, 04:01 PM
ethanhunteg ethanhunteg is offline
I've gathered from this and other posts that Hybrid can be a good tool for converting my raw files from VHS (HuffYUV, 720*480 using virtualdub guide), captured with to a format suitable for upload and sharing with family in Google Photos.
However, I have no clue what options to use and there are a million of them.
Attached are sample before and after using the following settings. Anything I should be adjusting?
Also I'd love to add a mask, all in one step -- is that possible in Hybrid?
x264 --preset veryfast --bitrate 6000 --profile high422 --level 4.1 --ref 3 --keyint 60 --direct auto --b-adapt 0 --sync-lookahead 9 --ratetol 2.0 --qcomp 0.5 --rc-lookahead 40 --partitions i4x4,p8x8,b8x8 --no-fast-pskip --subme 5 --aq-mode 0 --vbv-maxrate 6000 --vbv-bufsize 30000 --sar 1:1 --qpfile GENERATED_QP_FILE --non-deterministic --range tv --colormatrix bt470bg --demuxer raw --input-res 720x480 --input-csp i420 --input-range tv --input-depth 8 --fps 30000/1001 --output-depth 8 --output "C:\temp\1999clip1.264" -
Input Track: 1 (1)
Output:
Format: aac
Channels: 2 (reencode)
Sample rate: 48000Hz
Encoder: faac
Mode: bitrate
Mode Value: 160
Gain: 0.00 (-n)
Extras: low complexity
The following users thank ethanhunteg for this useful post: JaiFai4K (12-10-2023)
Capturing with VirtualDub [Settings Guide] lordsmurf Capture, Record, Transfer 102 11-17-2023 04:46 PM
Hybrid settings, AVI to x264, advice for best settings? nevs Encode, Convert for streaming 7 10-11-2022 05:32 PM
Starting my capturing project: VirtualDub and Huffyuv settings? ragu0012 Capture, Record, Transfer 16 09-10-2017 09:09 PM
