05-09-2021, 07:10 AM
EmielBoss EmielBoss is offline
I currently have the following workflow for capturing Video8/Hi8 tapes:
TBC camcorder --S-Video--> Panasonic ES15 --S-Video--> green AVT-8710 --S-Video--> Pinnacle 710-USB --USB--> Windows XP/VirtualDub 1.9.11
Now I would like to capture VHS as well. What should I change? Which VCRs or other devices should I look out for?
05-09-2021, 05:14 PM
Just replace the camcorder with a VCR, that's it.
That workflow is very lossy, I don't see why you have to use the ES15 since you have the line TBC and the frame TBC?
The following users thank latreche34 for this useful post: EmielBoss (05-21-2021)
05-10-2021, 02:59 PM
bookemdano bookemdano is offline
IIRC he needed to add the ES15 because he was getting weird artifacts when using the camcorder's line TBC + AVT-8710. He found that disabling the camcorder's line TBC resolved it, so he picked up an ES15 for line TBC duty.
But latreche34 makes a good point. Since you're changing your source to an S-VHS deck (assuming you get one with a built-in line TBC) you should first try eliminating the ES15 and go directly from the VCR to the AVT-8710. Only add the ES15 back in if the same issue appears, or if you aren't using a VCR with a built-in line TBC.
The following users thank bookemdano for this useful post: EmielBoss (05-15-2021)
05-10-2021, 04:31 PM
If top-tearing happens the ES-10(15) must remain in the workflow for that particular tape.
So sayeth the elders.
The following users thank BarryTheCrab for this useful post: EmielBoss (05-21-2021)
05-11-2021, 05:54 PM
cbehr91 cbehr91 is offline
I have captured lots of Hi8 tapes. All SP camcorder masters. Some have tearing/flagging, but not all. I only use the ES10 when necessary (while viewing a few minutes of footage to set light/dark levels I watch for tearing). Otherwise, I skip it and just use the camcorder line TBC. Use the exact same method for VHS.
The following users thank cbehr91 for this useful post: EmielBoss (05-21-2021)
capturing, vcr, vhs, workflow
Any differences in Video8 workflow compared to Hi8? EmielBoss Capture, Record, Transfer 6 03-30-2021 11:02 AM
Video8 and Hi8 capture workflow? davidprosser Project Planning, Workflows 3 12-31-2020 10:38 AM
PAL Hi8 / Video8 camcorders for capture? Asbesto Capture, Record, Transfer 1 11-24-2018 08:04 AM
Video8 capture improvement AJAX1 Capture, Record, Transfer 0 10-06-2015 08:52 PM
Adapting plugs: 2-prong to 3-prong adapters & power for computers Sossity Computers 7 12-11-2010 01:58 AM
