02-02-2008, 08:42 PM
Konfusion Konfusion is offline
I been looking at dvd recorders to record from my DirectTV HD DVR box. But im stuck on a few and not sure what to get.
Should i get
Philips 3575?
Panasonic DMR-ES10?
Toshiba XS Series?
A Different one?
Or should i use a capture card instead. if a capture card i have pci express. but i just want to be able to get the best absolute quality recorded from my dvr in xp and sp mode. will mostly be HD shows.
02-03-2008, 03:55 AM
Panasonic machines have the worst encoding quality of any DVD recorder. Period. If you take this hobby seriously, don't use these pieces of crap. The ES10 is a unique unit because of a set of filters it has. It can be useful for filtering a signal, but you pass that signal back out to something else to do a good recording. These are old, from 2005, and the capacitors all seem to be popping right now (right at the 2-year mark). I had to replace a capacitor just last week.
Philips 3575 is a newer 16:9 ATSC/QAM digital tuner machine, meaning it'll record HD in 16:9 format. It has a 160GB hard drive, and great encode quality from 1-3 hours. It has zero ability to clean up VHS, no filters.
The Toshiba XS series is a 160GB machine with a normal NTSC analog tuner, but it has filters that the user can turn off or on, and set to various levels. There is also some degree of bitrate control. It's more complicated to use than most, but works very well at cleaning VHS. Not as good as the JVC machines, but still a decent second place trailing a little behind.
To record from DirecTV HD -- and never VHS -- I suggest the Philips 3575 machine. These are still sold new for about $300 at some Walmart's and most Circuit City.
There are no PCIe capture cards that I'm aware of. They are all PCI or integrated AGP. PCIe is specifically a graphics slot. The choice in capture cards is much less these days (for Windows machines), since ATI and a few others left the arena -- at least left by making not-so-hot products. You have some items by Hauppauge, Matrox and Canopus, but at the price, the DVD recorder is easier, and can often be better quality anyway. Unlike capture cards, which are largely using chips made by computer companies (NEC), DVD recorders use chipsets by large video companies (Zoran, LSI Logic, Cirrus, etc).
02-03-2008, 05:48 AM
ok. i went out last night trying to find the philips at walmart and circuit city. ill have to try a few more stores. cause i already bought the jvc you told me about for vhs. ill have to keep trying to find the philips till i find one
thanks
02-03-2008, 08:21 AM
debwalsh debwalsh is offline
Try online, too. I just got my Phillips DVD recorder from Circuitcity.com for Christmas.
02-03-2008, 08:54 AM
ok i just bought it from amazon. will have it wed.
Thanks for the info...
Now i have
Philips 3575 and JVC DR-M10
woo hoo think im going to be doing good now.
Panasonic ES10 units for sale! (frame sync filtering!) lordsmurf Restore, Filter, Improve Quality 0 08-28-2009 03:30 AM
Panasonic DMR-ES10 vs. DMR-EH55 DVD recorders? Kenneth M Capture, Record, Transfer 1 03-02-2009 12:16 AM
Question on the Panasonic DMR-ES10 mrwhitethc Restore, Filter, Improve Quality 4 04-13-2008 07:30 AM
Philips 3575 Aspect Ratio Settings. Konfusion Capture, Record, Transfer 3 02-12-2008 08:09 AM
