07-23-2021, 07:32 AM
murre906 murre906 is offline
Please come with pal Betamax players, model and type that I can look at to possibly buy.
must have 2020 volt power. I live in Norway
07-23-2021, 08:37 AM
Have tried it but I have little idea of it there. So then I need help.
07-23-2021, 09:28 AM
Must buy pal betamax player must have 220V. I live in Norway. What do you recommend. With and without remote control
07-23-2021, 11:00 AM
lingyi lingyi is offline
Don't know who you're replying to, but the best reference is here: https://www.palsite.com/models.html
The problem is Beta (only Sony machines are Betamax) wasn't popular in Europe, so are hard to find. Don't know about 220V. You'll probably have to use a step-down transformer.
The selection becomes even smaller if you need Beta Hi-Fi or SuperBeta. Plus, because of the low popularity, there are no high end machines like the NTSC versions.
07-23-2021, 11:06 AM
As a fellow Norwegian, they're even harder to find here so if you need something advanced you may have to look at importing. The ones that show up for sale on finn and similar are the very early models in unknown shape most of the time.
07-23-2021, 11:45 AM
Thanks for reply. Is this a good player in relation to the price. And is it a pal player and has the 220v current
https://www.ebay.ca/itm/224530501523...kAAOSwulJg6xHQ
Wanted: Good Betamax player. cosmicwheelz Marketplace 0 04-29-2021 08:50 AM
Advice on VCR purchase for VHS capture? doodal Capture, Record, Transfer 6 03-06-2017 11:39 AM
VHS player purchase question on "Ask Slashdot" today NJRoadfan Capture, Record, Transfer 1 07-21-2014 06:14 AM
Will AG-1980 VCR TBC work for Betamax player input? deckhanddavy Capture, Record, Transfer 10 04-27-2014 05:53 PM
Help with VHS purchase, need VCR + capture advice via Email or PM Restore, Filter, Improve Quality 5 12-07-2013 06:27 PM
