03-06-2022, 08:33 PM
VHS_UK VHS_UK is offline
Hello again. After getting a new computer, I decided to install VirtualDub and HuffYUV codec again on my Windows 11 PC. After capturing some VHS footage, I tried to preview the captured video on both Microsoft's Film's & TV video player and VLC but were unable to play it.
I installed both 32-bit and 64-bit HuffYUV codec same as I did before on my Windows 10 different and did shown on the compression setting on VirtualDub.
VLC show the following error code:
VLC could not decode the format "HFYU" (Huff YUV Video)
Film's & TV video player show the following error code:
This item was encoded in a format that's not supported. 0xc00d5212
On top of that, loading the video file onto my PowerDirector software crashes it.
I even tried playing the video on MPC-HC player which crashes as well. On top of that, loading Quick Access crashes Windows file explorer if the video file is listed on last 20 recent files I clicked on. I tried looking on Google and on here and I keep getting the same 4-5 forum posts, none of which solved the problem. Could it be that the codec is simply too old to run on modern systems?
03-07-2022, 11:54 AM
I think it working on VLC now. For some reason it fixed itself. I do however have another problem which I'm going to post on the Restore, Filter, Improve Quality section.
PAL Hi8 chroma when played on Digital8 camcorder: 4:2:2 or 4:2:0? polygraph Capture, Record, Transfer 5 07-22-2017 05:00 PM
Accidentally played moldy tape in VCR - what should I do? Intergalactic Pancakes Video Hardware Repair 9 07-02-2017 04:18 PM
DV or Huffyuv for archiving videos? metaleonid Capture, Record, Transfer 3 07-23-2013 05:59 AM
Capturing Settings for Encoded Videos Superstar Capture, Record, Transfer 1 07-31-2010 02:37 AM
Capturing Settings for Non-Encoded Videos Superstar Capture, Record, Transfer 2 02-10-2010 07:54 AM
