03-28-2022, 06:44 AM
Not on the recommended list but...
Any opinions on the JVC HR-S5700AM?
No remote would come with it; do I need a remote?
I have an ES15 and DVK-200 to use with it.
03-28-2022, 08:00 AM
Similar to other newer JVC SVHS decks without the TBC/DNR feature. Only difference between the recommended TBC/DNR models from the time is the lack of the TBC/3DDNR circuit, these have a simpler 2D NR (and Y/C separation for recording) thing instead. Should work nicely with the ES15. Main feature on this one is that it's a multi-system plays both native PAL, MESECAM and NTSC with selectable NTSC 3.58 (native), NTSC 4.43 and PAL60 output. (Normal PAL ones only let you output PAL60 when playing NTSC tapes I believe). Also has tuner capable of receiving NTSC which isn't relevant these days.
Hushpower (03-28-2022)
03-28-2022, 08:51 AM
Thanks Hodgey, much appreciated.
03-28-2022, 09:28 AM
Also, any thoughts on the need for a remote?
I do have a LP20878-016 from another JVC VCR which went into the bin years ago. It looks the same as the remote for the 5700.
03-30-2022, 08:09 AM
Disregard the above, I've bought the machine and my previous remote works well. Not super-impressed by the video quality but there is a slight improvement over my VHS machines.
04-07-2022, 09:56 AM
What are your other VCRs for reference, can you rank them from best to worst by the image quality you get from each?
recommended vcr+line tbc ---(Y/C)--> recommended frame tbc or "tbc-ish" ---(Y/C)--> capture
04-07-2022, 08:48 PM
Panny EZ-48, LG GC990W, Panny ES-35, LG 299. The combos (48, 35 and 299) have S-video out for the VHS side.
The first two are almost brand new, which probably helps. I do run the 990 and 299 through an ES-15, which adds to the cost (48 and 35 have strong line "TBC"s).
The following users thank Hushpower for this useful post:
lollo2 (04-08-2022)
06-10-2022, 10:43 PM
Pulled the top off my 5700. Gave the heads a good going-over with my wire brush so that should help. Just kidding! Got some gunk off the heads with paper soaked in Isopropyl alcohol.
A couple of questions: I spotted a small piece of what looks like shrivelled-up belt, shown in the first pic. Is that an issue? VCR runs OK.
What else should I clean/do while I'm inside (I did do a search but couldn't find much on stuff other than the video drum and heads)? Overall pic attached.
06-11-2022, 02:24 PM
Ah, a Techmoan fan....
My business partner does a tone perfect impression of TechMoan and everytime he does any maintenance on a machine he narrates it as TechMoan and starts coming out with dubious repair advice as per Mat, it's hillarious.
The number of machines I think he damages in an attempt to repair them is probably substantial. Sticking cotton buds inside a V2000 machine to clean the video heads was a marvel
