03-28-2022, 11:58 PM
Closecall Closecall is offline
I was recording a RCA T-120SHG VHS tape when I noticed a strange line towards the top of the recording in VirtualDub. The first 50 minutes of the tape played great and stable. Then all of a sudden a weird line appeared at the top of the video (image attached). I tested it in both my Mitsubishi HS-HD2000U and my JVC SR-VS20 , going into my BVTBC10 and then a ATI AIW USB.
If in fact it is a tape issue, is there anyway to fix this?
whether with TBC adjustments or other methods.
Thank you
03-29-2022, 03:39 AM
lollo2 lollo2 is offline
Post a sample of the video to see if the defect can be reduced in post-processing
03-29-2022, 06:49 AM
That's tape related, It should be seen if you look closely on the tape surface near the edge. Are you capturing or recording to the tape? If recording just use another tape, if capturing there are some software solutions but it is not going to be any better than what the VCR's DOC did already.
03-29-2022, 07:59 AM
With the above, that looks like a tape scratch, especially it hardly moves on the image and occurs in both fields.
That looks (from the tiny image) like monumentally aggressive drop-out compensation, I guess you need to start doing some crazy tedious AVISynth work. I'd do this in After Effects, there are techniques to improve it, but you've got to be pretty dedicated and start making masks etc to really handle it near-unnoticably.
Unfortunately, there's not a quick solution to that one, the information is 'missing' on the tape.
capture, damage, recording, tear, vhs
What to buy to convert videotape to DVD? colas Capture, Record, Transfer 12 01-04-2021 05:13 PM
Soiled 1/2-inch reel videotape? halopower Project Planning, Workflows 2 11-18-2020 07:51 PM
Do different variations of PAL apply to videotape? Etcetera Videography: Cameras, TVs and Players 2 03-03-2020 09:26 PM
Is a JVC HR-9800U VCR really the best quality for videotape transfers? bmw5002 Capture, Record, Transfer 5 08-02-2012 11:41 AM
PAL videotape to DVD transfer problem lordsmurf Restore, Filter, Improve Quality 0 08-23-2010 03:04 AM
