09-03-2022, 04:06 PM
dudemcgraw dudemcgraw is offline
There are so many options when it comes to non-cotton swabs to clean the heads on a VCR, I want to make sure I buy the best quality product that won't damage the heads. A camera sensor cleaner would work well, I just would be curious to hear what people use and what works. I would of course be using it with rubbing alcohol rather than whatever cleaner it comes with (if any). Please advise, thanks!
09-04-2022, 10:12 AM
BarryTheCrab BarryTheCrab is online now
My preference is a flat sensor swab, sort of looks like a flat anvil, and near pure alcohol.
09-04-2022, 08:38 PM
nicholasserra nicholasserra is offline
I use these
https://amzn.to/3KTSa79
09-04-2022, 11:59 PM
Foam quality has tanked, many have become cheap open cell, which is bad, snags heads. So only chamois, dSLR sensor swabs. Foam too dangerous now, gamble.
Cleaning my JVC SR-VS30EK VCR heads? Patrick_S Capture, Record, Transfer 1 02-08-2021 01:47 PM
Cleaning MiniDV/Hi8/VCR heads with swabs? gloubu Video Hardware Repair 1 02-06-2021 07:34 PM
VCR cleaning swabs to use on heads? lojelo5 Restore, Filter, Improve Quality 18 03-21-2020 01:44 PM
Digital 8mm dirty heads; Use a cleaning tape? reddragon81088 Video Hardware Repair 13 07-27-2017 07:28 PM
Cleaning VCR heads proper methods? fuzzblaster Capture, Record, Transfer 1 08-31-2010 07:44 PM
