10-29-2022, 06:56 PM
PokerPlayer77 PokerPlayer77 is offline
I want to have raw lossless master digital copies to backup my family home videos. Is there a guide available?
Here is what I've done so far. Is this sufficient to get the best quality raw analog source backed up before learning how to edit/convert the videos?
So far:
1) JVC S9911U > Startech USB3HDCap
2) VirtualDub installed with HuffyUV
3) VirtualDub Steps:
File>Capture AVI
File>Set Capture File>FamilyVideo01.avi
Device>Selected
Video>Preview selected
Video>Compression>Huffyuv 2.1.1
Audio>Enable Audio Capture selected
Capture>Click Capture Video
NOTES:
1) I noticed the window on right under Sync>Current error it says -3ms (is this normal)
2) Is there a guide that shows the best settings to use while capturing raw analog video so I have the best master quality file saved on my computer, or am I doing it the right way now already to get the best possible backup master copy of the VHS into digital format before learning to do any editing?
Thank you!!
I found this guide: https://www.digitalfaq.com/guides/vi...virtualdub.htm
I'm using VirtualDub 1.10.4
Capture>Settings I changed framerate 59.9405 to 29.97
Video Format> 640×480 (((Should I be capturing my raw master copies at a different resolution)))?
Any other tips would be greatly appreciated!
Thanks again
10-31-2022, 11:30 AM
Thanks again
Yep 720x480 interlaced 29.970 fps, stick to that
And i'm not sure Vdub is the tool for that (never used in 20 years for caps), i still use virtualvcr and i hear amarectv is not bad. Food 4 thought
10-31-2022, 11:31 PM
LS reckons you should be using Virtual Dub 1.9.11
I like it because of the histogram.
Green AVT-8710 working correctly? Hangle Capture, Record, Transfer 4 12-31-2020 09:32 AM
Best capture format for master VHS-to-digital? (Huffyuv vs Lagarith vs MPEG) rocko Capture, Record, Transfer 10 09-06-2018 11:20 PM
Starting out with VHS to digital archiving? Dominik78 Capture, Record, Transfer 14 05-10-2018 10:35 PM
Choosing a digital format video8 archiving masters? AJAX1 Capture, Record, Transfer 29 05-13-2015 01:04 PM
Archiving slides to digital: Blu-ray DVDs for storage? Scan quality? kpmedia Photo Processing, Scanning & Printing 0 10-17-2010 05:56 AM
