11-19-2022, 01:50 PM
gertymcgee gertymcgee is offline
I'm wondering if anyone else has run into this issue with their 600 USB. The cord that plugs into the device seems pretty loose. Is this typical?
It is causing capture issues where the video is flickering. Attached is an example capture to this post. Seems to get worse when you play with the cords.
Is this a known issue? Do I need to purchase a new capture card?
Thanks!
11-20-2022, 08:28 AM
cinemaman cinemaman is offline
Do you have a TBC in the chain (in other words are you sure the cord is the cause of the image disruption) ? Is it possible to show a photo of the "loosness" of the cord ?
11-20-2022, 08:24 PM
Where did it come from? There are common 600 issues, due to using the wrong AV plug. I've seen this way too often on eBay listings, comes with random cords. Sometimes not even something that fits it, obviously wrong plug shape entirely.
Are you properly using it with the USB extension?
Beyond the 600, you have s-video cables, or other workflow gear. So some troubleshooting required, to isolate the error origin.
Lack of TBC could be an issue.
However, what you're seeing here is what happens when you try to use ATI 600 USB with Win10, sometimes Win8. Are you using that OS? That card cannot be used with that OS. The OS is bad for capture, well known issue, do not blame the quality card.
Can you identify AC cord for old Panasonic VTR? Formica Video Hardware Repair 8 10-13-2020 01:44 PM
Tape end came loose from cassette in player koberulz Capture, Record, Transfer 2 08-03-2017 04:12 AM
JVC VCR power cord mod (with photos) volksjager Video Hardware Repair 2 10-23-2012 06:00 PM
TBC-1000 S-Video loose connection? cc4npg Video Hardware Repair 1 08-17-2011 12:38 AM
Need new battery and power cord for Dell Inspiron laptop admin Computers 3 08-16-2011 02:29 AM
