01-10-2023, 06:17 AM
roberthartman roberthartman is offline
I needed Windows 7 to be able to run a lordsmurf conversion workflow and ran into a couple issues while installing, so I wanted to post the fixes.
I more or less followed these instructions, which I believe were pretty solid. This site was also helpful.
I downloaded a Windows 7 Pro ISO and attempted to run the installer inside the ISO directly, but would get an error that there was a corrupt file. I then attempted to burn the ISO to a DVD thinking that would help, but it did not. To get past this issue, I did fix 1, listed below. I believe the file in question was winload.efi in one case and perhaps autorun.(not sure what extension...) in the other. Attachment IMG_3950.jpg shows the error encountered when booting to the DVD, I believe.
After fix 1, Windows 7 setup would run by booting to the setup DVD (although at this point I believe setup would have run by directly opening the installer inside the ISO), but it would hang on a Windows startup screen after one of the reboots. To get around that, I performed fix 2.
BIOS changes that fixed things (see IMG_3954.jpeg):
1. "Secure Boot": change to "Disabled"
2. "Legacy Support": change to "Enabled"
The warning in IMG_3949.jpeg regarding partition ordering did not seem to cause any problems; I ignored it.
01-12-2023, 02:19 AM
Dual booting from a partition never works well. Not now, not 10/20/30 years ago. The only way to safely "dual boot" is to swap hard drives. But physical removal isn't needed, just use a switch like this: https://amzn.to/3IIs5Ji
I'm amazed how many viewed that Youtube video has. It's total crap, both quality and content.
If this is for a laptop, I'd again only dual boot if I had 3x drive slots, and could change the boot drive in BIOS.
In time, partition boot setups always fail. Always. Short term is fine, long term is a mess.
01-12-2023, 06:26 AM
enois enois is offline
I use a desktop PC with 3 operating systems on the same hard disk (win XP + win 7 + linux) with no problem in switch between the OS's.
The multi boot is managed by GNU Grub, maybe this is the reason for proper operation in multi boot.
ATI CMC in Windows 10 64-bit? asa67 Capture, Record, Transfer 2 11-22-2016 11:42 PM
Windows XP video 'capture' PC vs. Windows 7 video 'Edit' PC? rocko Project Planning, Workflows 5 02-08-2015 03:34 PM
Editorial: Windows 7 vs. Windows 8 kpmedia General Discussion 6 03-01-2013 10:30 AM
Windows XP and Windows 7 dual-boot issue: they won't work? colintyvu Computers 1 01-09-2013 06:48 AM
ATI All In Wonder drivers for Windows Vista or Windows 7 ? Mejnour Restore, Filter, Improve Quality 12 02-01-2012 05:27 AM
