01-29-2023, 10:06 AM
kingadam1985 kingadam1985 is offline
Hi!
I try to improve the quality of my vhs capture. I would like to remove or make the black horizontal lines less visible and improve the washed out color in avisyth. Can somebody recommend me where to start.
01-29-2023, 02:41 PM
You can try this for the black comets (it may need tweaks)
AVISource("mljet cut.avi")
assumetff()
converttoyv12(interlaced=true)
QTGMC( Preset="fast", TR2=1, EdiThreads=4)
SpotLess(RadT=5,ThSAD=1000000,ThSAD2=1000000,pel=2,chroma=true,BlkSz=8,Olap=4,tm=false,glob=false,bBlur=0.0)
selecteven()
spotless does the job basically but must use a large temporal radius; i'm not sure it'll be ok for small details throughout the video
ATI 600 horizontal lines interference? chrisbati Capture, Record, Transfer 2 09-02-2021 12:03 PM
Virtualdub VHS has horizontal lines, color problems? kikofaria00 Restore, Filter, Improve Quality 1 05-06-2021 05:30 PM
Faint horizontal lines in VHS capture? Crisht13 Restore, Filter, Improve Quality 0 01-16-2021 07:03 PM
How to remove horizontal lines caused by damaged tape? spanak Restore, Filter, Improve Quality 14 06-04-2018 04:41 AM
Remove extra lines (empty lines) from copied/pasted text with Notepad++ kpmedia Computers 1 10-07-2011 05:32 PM
