03-15-2023, 02:52 PM
srmusico srmusico is offline
Hello guys!
I have bought a really cheap Kona LHi + Breakbox + some cables and works like a charm.
Also, the Fan noise is unbearable...
I have read some other AJA and Black Magic users who have changed their original fan included (the noise seems to be because of the fan low quality)
What do you recommend in this model? just to take out fan and leave chip without anything? remove fan and install a passive heatsink? or replace to a new fan?
If is better to replace to a new fan, what could be the correct candidate ?
Im doing tests and at this point, i have fan "hanging" out just from cables and one passive heatsink placed with thermal paste and 2 plastic flanges (provisional tests xD) and temperature is from 75º to 83-84ºC.
Thanks you so much in advice!!!
12-29-2023, 08:38 PM
mrmuy97 mrmuy97 is offline
What is the rest of your workflow, exactly? What VCR, to what (if any) TBC device(s), to which inputs of the LHi (Y/C BNC connectors on breakout cable?)
Yes. The earlier serial numbered LHe Plus and LHi cards have the crappy Sunon fan shown in your picture. They seem to be almost guaranteed to be going bad by now. The later cards got an upgraded fan that is better quality and seems to be lasting just fine in comparison. You can call AJA directly and they'll give you all the info about fan replacement. Very simple to DIY.
Absolutely NOT EVER under any circumstance!
Not unless you have enough active airflow directed to pass over that heatsink, and it's an appropriately-sized heatsink, and the temps stay below 60-65 C MAX.
Yes.
If is better to replace to a new fan, what could be the correct candidate?
See above; you can contact AJA support directly and they'll give you any info you need help with.
I would recommend avoiding that chip temp from staying over 65 C for any period of time. I think your 75-85 C temps are showing that you need to get a proper active cooling solution for it. See above; you can just get a new/upgraded replacement fan from AJA.
recommended vcr+line tbc ---(Y/C)--> recommended frame tbc or "tbc-ish" ---(Y/C)--> capture
12-29-2023, 11:16 PM
Our British brother did this replacement:
https://youtu.be/EmwCkJBqKzI
aja, cooler, heatsink, kona, mod
Getting Aja Kona LSe working with Windows 10? Qaenos Capture, Record, Transfer 14 08-11-2022 03:48 PM
Aja Kona Lhi best codec waloshin Capture, Record, Transfer 1 01-16-2021 11:49 PM
Capturing VHS with the AJA Kona LSe card? Aerith Capture, Record, Transfer 61 08-14-2020 08:35 AM
Vhs capture --- kona aja lhi ... Not impressed!! johnnysh Capture, Record, Transfer 3 03-21-2020 02:17 PM
Diagonal line noise on VHS video? Luma noise? bilditup1 Capture, Record, Transfer 66 10-17-2015 01:03 AM
