05-07-2023, 07:34 PM
Sac John Sac John is offline
I'm capturing numerous Hi8 tapes to a Mac. Camcorder > TBC > Capture card > Mac. Per LS advice, the audio cables skip over the TBC and go straight from the camcorder to the capture card.
I read somewhere, not on this forum, that audio drift (ie, losing audio sync) is "inevitable" when capturing long spans of tape time at once. I want to capture as much of my tapes at one time as possible so I don't have to baby-sit the project any more than necessary. Ideally, I would just capture the whole two hours at once and come back and clip it up later, but it sounds as though that's asking for trouble. I'm only focused on archiving my tapes at this point to avoid further deterioration, not organizing or editing them.
Is there a rule of thumb for how long to capture at one time before stopping the capture and restarting mid-tape?
Any other tips to avoid audio drift / audio sync issues?
05-07-2023, 08:15 PM
What camcorder, what software?
This is not true.
But I've seen some folks also make this claim. The actual culprit is always settings, or the capture device, or both. Some eventually discover this, others are stubborn and continue to believe in nonsense/conspiracy/etc. The latter is easier. (That translate to everything, not just video. Science/truth/facts can be hard to grasp, made-up crap is easy to "understand".)
the whole two hours
FYI, that's not even remotely long. EP mode is long, 6/8/10 hours.
For example, even then, with 6/8/10, I have few issues with long runs. Noting I deal with more stubborn tapes, so sometimes I have to recapture segments. It's a source issue there, not hardware or software. Horrid errors can still confuse even the best TBCs.
Nope, no trouble.
What you want is perfectly reasonable, and is what I do frequently.
I'm reminded of James Carville from '92, his famous phrase: "It's the economy, stupid".
Here, "It's the hardware and software, stupid."
Not too far away from KISS, "Keep it simple, stupid."
And no, I'm not calling you stupid.
But it really is that basic.
The TBC is fine. The monkey wrench is the Mac, the software, and the capture hardware, both camera and capture card. Those are the variables that drop frames.
05-07-2023, 11:58 PM
Sony TRV-81 Hi8 Camcorder
VideoGlide for Mac
05-08-2023, 12:01 AM
Does that TRV-81 have line TBC?
If so, confirm it is enabled in the menu of the camcorder.
That alone is probably not enough, but we do need to start there.
And you have the TBC-1000, right? And it's between the camcorder and capture card?
Losing frames, sync issues when filtering/muxing in Hybrid? VHS_UK Encode, Convert for streaming 16 05-02-2022 11:12 PM
Audio/video sync issue. Capturing with Virtualdub Turok81 Capture, Record, Transfer 6 11-14-2016 12:29 AM
Capturing and audio sync, taking another stab at it! theglenlivet12 Capture, Record, Transfer 2 05-07-2016 09:17 AM
Audio sync problems, about to give up capturing video! theglenlivet12 Capture, Record, Transfer 7 08-21-2015 07:19 AM
Capturing VHS with VirtualDub - audio and video out of sync. avz10 Capture, Record, Transfer 3 01-13-2013 06:25 PM
