08-13-2023, 08:09 PM
Thor Thor is offline
I got some issues with captured VHS-C that seems to only happen to a few ones. See attachments.
The picture has like a yellow (neon green?) and magenta all over it, I took a fairly good screenshot so it's easy to spot.
The video shows that on some captures it has some bad movement at the bottom of the picture, while some others are stable.
It has all been captured on a LG RC389H.
08-13-2023, 09:40 PM
Did you black out the video or that's the defect you're complaining about?
The bottom noise strip is called the head switch, it's inherit to the format, some tapes have more of it some have less, The chroma noise in low light is normal for the format, You can reduce it by having a S-VHS VCR built in line TBC and use S-Video cable instead of composite.
08-13-2023, 10:03 PM
Yeah I blacked out the rest of the frame, and damn I was hoping that it would just be some dirt on the tapes that I could clean. So it's called chroma noise and I can reduce it with better equipment, how do I connect it to my PC so I can transfer it though?
08-14-2023, 02:31 AM
What are you using now? Recording into DVD discs, that explain some of the poor quality you're getting. A S-VHS VCR with line TBC has a DNR function tight to the TBC that cleans up some of that nasty noise, It works 90% of the time but there are tapes that don't cooperate with TBC being on.
JVC HR-S8960 strange capture defects, improper lines captured? FinnTape79 Capture, Record, Transfer 5 07-16-2023 12:48 PM
Captured the videos, now what's next? SinghDk Restore, Filter, Improve Quality 3 01-24-2020 01:54 PM
Capture hardware recommendations, gear servicing/defects? Qaenos Capture, Record, Transfer 1 01-09-2020 01:30 AM
Mistakenly captured into MS-YUV 16 bit metaleonid Restore, Filter, Improve Quality 6 01-27-2015 03:46 PM
No Audio Captured yargellham Capture, Record, Transfer 7 01-11-2005 01:53 PM
