01-15-2024, 03:08 PM
Gary34 Gary34 is offline
I downloaded Huffy from https://www.digitalfaq.com/forum/vid...lters-pre.html then I followed these steps https://www.digitalfaq.com/forum/vid...l-huffyuv.html and my DOS box is saying this.
01-15-2024, 05:20 PM
Feedbucket Feedbucket is offline
Dosbox is an emulator and has nothing to do with your Windows install. Use the Command Prompt (Windows menu, type "cmd").
Upon reading those directions, I see how someone could be misled. There are repeated references to a "DOS box" which I don't believe is really the right term, though it is DOS-like functionality.
The following users thank Feedbucket for this useful post: Gary34 (01-15-2024)
01-15-2024, 07:19 PM
Its still not working for me
01-16-2024, 06:36 PM
If you're referencing c:\huffyuv.inf in that command that means you'll want huffyuv.inf (and its accompanying dll) to reside in the root of your C drive. Looks like the directions are again not all that clear....
01-18-2024, 02:00 PM
here is what I am seeing now
01-18-2024, 03:37 PM
hofmand hofmand is offline
Use my installer: https://github.com/hofmand/video-codec-installers
01-19-2024, 07:53 AM
Alright I think I got it now. I just used the links that I left in the first post. They worked. I just went back and checked to make sure I was doing everything right and when I tried it again it worked. I had to make sure I right clicked and changed my command prompt to run as administrator and that my files were unzipped into the right spot.
huffyyuv, windows 10 64bit
Which Huffyuv version, how to install Windows 10 x64? Oakleaf Capture, Record, Transfer 9 04-26-2019 03:26 PM
VirtualDub 1.9.11, Huffyuv 2.1.1, Windows 10 issue jbur Capture, Record, Transfer 0 03-09-2019 05:22 PM
Done with Huffyuv, won't install in Windows 10? drzapp Encode, Convert for discs 14 01-12-2019 09:42 AM
