01-27-2024, 07:35 PM
licehead licehead is offline
MODEL: JVC HR-S7900U
Noticed today when trying to capture video that the VCR started buzzing. Doesn't matter if powered on or not, the moment I plug in the power it starts. Will attach video, also produces a rolling kinda static when trying to playback that was not there previously.
Bad capacitor? bad fuse? Any guidance before I get a little to gung-ho with a soldering iron and do more damage.
01-28-2024, 03:44 AM
That's a ground loop you're hearing:
https://www.youtube.com/watch?v=1_l__9s89T0
https://www.sct.com.tw/articles/4-ef...o-interference
Solution: https://shorturl.at/fgoxW
01-28-2024, 12:15 PM
No, that is not a recommended solution, He needs to address the root cause not patch it with quality reduction of audio. Check your cables, connectors and ground as necessary, don't leave the problem there and try to hide it with masking tape.
01-28-2024, 10:28 PM
The problem is not audio during playback / capture. The hum is definitely coming from the back right of the deck near where the power cable goes. I tried just about every outlet in my home and the moment I plug it in it starts to buzz. No other cables are plugged into the unit, no tape inside. This has never been a problem until very recently.
01-29-2024, 01:27 AM
timtape timtape is offline
The high frequency noise appears to be coming from the high voltage side of the switch mode power supply. The deck probably needs to be checked by a skilled service tech.
01-29-2024, 01:52 AM
Did you not properly put this unit on a UPS (in the past), and had it directly into the wall outlet?
Uh-oh.
This is a coincidental post for me. The reason I just woke up is because we had a random power surge. Not a dip or brown-out, but a surge. The night light intensified, then burned out. The LED on my clock got bright. I could hear the refrigerator groan from several rooms over. The battery backup (UPS) in my room, which is used for my TV and players, went bonkers and screamed me out of bed.
So if anything ever happened like this, and you had a VCR on the wall outlet, you're screwed. It can happen at any time, while at home, while not at home. Ths is why a UPS is essential for AV gear, computers, and just anything valuable in general.
VHS Audio Buzzing - How to fix? MermaidNatalia Video Hardware Repair 8 08-29-2023 06:42 PM
Pinnacle Capture driver not installed when plugged in? VHS_UK Capture, Record, Transfer 3 10-31-2022 05:53 AM
JVC SR-V101US buzzing audio issues? MrEightThreeOne Video Hardware Repair 14 02-11-2017 09:15 PM
Which devices can be plugged into a USB hub? Which ones cannot? Sossity Computers 3 07-19-2012 06:02 AM
Do modems/routers need to be plugged into seperate power outlet? Sossity Computers 1 11-21-2011 05:53 AM
