03-28-2024, 02:38 PM
badonica badonica is offline
Hi,
Been trying out a TBC 1000 which was capturing great then
frames started dropping and then the video picture distorted; went as if Macrovision had kicked in.
Was using:
ATI 600 USB
Virtual Dub 1:1:9
Windows XP
ASUS P4P 800 Motherboard
JVC HR-DVS3EK Mini DV SVHS (TBC)
Tried a couple of tapes, same results?
I’ve carried some MPEG2 captures on this set up with a Canopus EMR 100 USB
and there was no issues ( without the TBC)
Any thoughts?
03-28-2024, 06:11 PM
aramkolt aramkolt is offline
Guessing the TBC-1000 needs a recap. On mine, 80%+ of the caps were out of spec, with many being extremely out of spec.
I'm not totally convinced that you absolutely need a frame TBC if you're getting no dropped frames and no vertical jitter with a certain capture chain. I get it would be lame to have to re-capture something where these issues were seen after the capture though.
03-28-2024, 11:36 PM
Open the TBC-1000, and take a photo of it. I need to see it. Just 1 clear photo of the insides is all I need.
Where did the unit come from?
When?
JVC TBC cause dropped frames, TBC off okay? idan182 Restore, Filter, Improve Quality 4 10-17-2023 07:31 AM
Never had dropped frames in VHS capture until now? lostinrock Capture, Record, Transfer 2 12-05-2020 09:23 AM
VirtualDub ATI 600 USB dropped frames? Ohank Capture, Record, Transfer 15 06-17-2020 12:44 PM
Dropped/inserted frames? koberulz Capture, Record, Transfer 4 07-27-2018 03:28 AM
