07-18-2025, 07:25 PM
Gdogg60 Gdogg60 is offline
Hello all
I am pretty new to converting vhs to digital and have learned a ton from this forum. I did some searching and did not find a solution to an issue I am seeing. Randomly video seems to be compressed to the top when I playback with VLC media player. This is for the duration of the video. How do I resolve this issue?
This is my setup:
JVC HR-S7800S
Datavideo TBC-1000
ATI Pro 128 Theater Rage
VirtualDub 1.10.4
I will attach some screenshots below. I appreciate the help.
07-18-2025, 08:28 PM
Aya_Rei Aya_Rei is offline
Does this show up when you view the video file in VirtualDub or any other program?
Just to make sure it's not a VLC issue
07-19-2025, 07:31 AM
I tested playback with virtualdub and it did the same. I also tested on another pc and it did the same.
07-20-2025, 11:03 AM
What are all of the exact capture settings?
Do not use VirtualDub 1.10.x to capture. This is a possible problem. Re-capture with 1.9.x
Another possible issues is the ATI drivers are wrong. Those old 128 and 128 Pro cards can be a PITA to install, often requiring "hacking" (unconventional non-easy installs). That's why I haven't suggested these cards for years now. There are easier paths with ATI AIW.
The root issue is 720x240 is being recorded in a 720x480 palette.
AVI audio unsyncs when compressed to MP4? malfc Capture, Record, Transfer 5 07-23-2024 11:02 AM
Lossless VHS captures to compressed archive format? MrEightThreeOne Encode, Convert for streaming 9 03-31-2024 03:44 PM
VHS to compressed format, crop the edges? Jayce72 Capture, Record, Transfer 14 06-24-2020 10:47 AM
Using VirtualDub for screen captures (for menus) lordsmurf Author, Make Menus, Slideshows, Burn 1 12-10-2007 03:39 PM
The Amazing....Compressed Air! Tcel93 Blank Media 0 10-04-2005 07:26 AM
