07-24-2025, 01:15 PM
Max33 Max33 is offline
I bought an ATI AIW 650 usb capture card and hooked it up to an old Win7 laptop through a composite cable. Everything works up until I play a VHS tape:
-First, I tested it with my old PS2. Transmits video and audio just fine
-Hooked up the VCR, menu shows fine but as soon as I hit play, the video comes through for a split second then turns to static
-Hooked up the VCR to a TV with the same composite cables and video plays normally
--Same results between using Catalyst Media Center and Virtual Dub.
Based on the PS2 and VCR menu appearing, I know it's not an issue with the USB capture device itself. Since I'm able to play video normally using a TV, I know the VCR and video signal coming from it is fine. Any idea what could be causing the issue?
VCR: Panasonic PV-9450
07-25-2025, 01:04 AM
Gary34 Gary34 is offline
I believe that card has really bad AGC issues. https://www.digitalfaq.com/forum/vid...i-650-usb.html
07-25-2025, 09:27 AM
Turns out using a late VHS and VCR with macrovision detection was the issue. My home video played fine.
07-25-2025, 10:17 AM
Welcome.
The 650 a terrible card that should be avoided. It has some of the worst AGC issues ever seen in a capture card. That means the image randomly darkens and brightens.
650 is also not an All In Wonder (AIW).
Sony Beta SL-F60 displays black & white image? AdamSmithee Capture, Record, Transfer 2 07-09-2025 04:10 AM
Part of tape only displays properly on fast forward? Benthony Capture, Record, Transfer 14 08-30-2023 09:10 AM
ES15 picture occasionally gets gray and static-y maldata Video Hardware Repair 7 07-24-2021 04:09 PM
VHS Software displays black lines, splitting video JJtheJJpro Capture, Record, Transfer 9 04-10-2020 03:05 PM
Interlacing on HD progressive displays? admin Capture, Record, Transfer 2 12-02-2009 12:42 PM
