06-01-2026, 09:14 AM
venaas venaas is offline
Hi!
I am looking for the H2.16 firmware for the Leitch dps-575. Does anyone have a copy of the zip?
I can find the G-version, but what I have understood they are not interchangeable.
Alternatively, is it possible to fetch the firmware from a 575 that already has the H2.16 installed?
Yesterday, 01:39 AM
As far as I know, to dump the firmware, the chip has to be de-soldered and put on a chip reader to be able to dup its contents.
Today, 07:12 AM
Thank you, and interesting!
I was in luck and talked to someone that had the firmware. I attached it to this message. Note that I haven`t yet tested it, but will do it soon
Today, 10:43 AM
radiokom radiokom is offline
If it has EPROM you can experiment with clear chip. If upgrade does not work simply push back original. But otherwise I would not advise to upgrade firmware. It is a gamble - if update is not successful you have dead unit.
dps-575, h2.16
Is a Leitch DPS 575 any good for standalone TBC? VHS_UK General Discussion 2 03-19-2022 04:24 PM
Opinions on Leitch DPS 470 for capture? pereirafch Capture, Record, Transfer 5 11-16-2020 10:17 AM
Leitch DPS-235 manual? four Video Hardware Repair 9 10-15-2020 10:22 AM
Leitch DPS-475 fail "no loadable firmware found" JohnGalt48 Video Hardware Repair 4 06-23-2017 02:49 PM
Putting the DPS/Leitch DPS-235 TBC to the test NJRoadfan Restore, Filter, Improve Quality 9 09-19-2012 10:44 AM
