11-15-2009, 03:19 PM
rlschoemer rlschoemer is offline
Just got the last piece of hardware TBC-1000.
Now what is the right hardware hook-up?
I assume that the TBC goes after the JVC S-VHS then the BVP+ then to the MP-6000
Before I start learning all adjustments does the TBC feature on the JVC get turned off, do any other features get turned on or off.
Will do some experimenting to see how everything else works.
11-15-2009, 09:18 PM
VCR > TBC
TBC > proc amp
proc amp > digital recording device
TBC on VCR can be on or off -- whatever makes picture look best. Usually it is left on, for most tapes. Only turn it off if you see problems with the tape, such as tearing or the image, jumping, jittering, or other odd errors that otherwise disappear when TBC is turned back off.
Experimenting is a tape-by-tape process, you should re-examine all settings anytime you put a new tape in the VCR -- from the VCR (audio and video settings), to the proc amp, to the recording machine.
I wish you well.
11-19-2009, 07:57 AM
As I was wiring everything was curious. Is their a current replacement item for the Elite Video BVP4+, does DataVideo make something that would replace it ??
Thanks for your responses
11-19-2009, 08:14 AM
Yes, there is the DataVideo TBC-7000. Best price (and service) for this item tends to be from B&H for $960 plus shipping. However, I've never used it, so I don't know how well it works OR if it is PAL-friendly.
It's button-based, which I personally hate. I want knobs that I can oh-so-gently nuzzle to the left or to the right, when tweaking my values.
PDF manual for it is attached.
According to some information pulled up via Google searches, it appears this might be PAL compatible, although at least 1 item is disabled in "PAL mode". I refer to the "tint" control, one of the 4-5 proc amp functions.
VHS tearing - hardware to fix it? admin Restore, Filter, Improve Quality 2 10-01-2009 05:30 AM
Best Hardware & Software for restoring ninjastriker Edit Video, Audio 10 08-09-2006 12:21 AM
What having the right hardware could do for you markatisu Restore, Filter, Improve Quality 3 09-08-2005 08:53 AM
Looking for some hardware suggestions dmsinger Capture, Record, Transfer 12 02-12-2005 03:01 AM
Understanding hardware strangepork Computers 1 10-19-2004 05:42 AM
