09-28-2012, 08:55 AM
juhok juhok is offline
I happen to got the same material recorded to VHS and also the original BetacamSP master. So how do they compare? Download and find out.
UTVideoCodec, converted to 4:2:0 for compatibility (Beta was sampled at 4:2:2).
http://cdn4.digitalFAQ.com/juhok/Pla...camSP_ULY0.avi
edit: Maybe more videos later with some 'real life' material.
09-28-2012, 09:50 AM
Ahh, VHS --- chroma shifting (color bleeding) and high frequency noise.
What surprised me the most on this clip was the identical luma resolution. Both videos seem to have equal sharpness?
09-28-2012, 10:04 AM
I have to disagree. Luma resolution is greater in BetaSP version.
Mouseover PNG luma comparison: http://www.siluriformes.net/videohel..._GBA_Luma.html
Aside from the blurred edges of sharp contrast objects, BetaSP has some good definition of surface texture on the game console where VHS has just noise.
Admin refused to unhide hidden content
nothing will help to see hidden content
The following users thank juhok for this useful post: lordsmurf (10-05-2012)
09-28-2012, 11:07 AM
You're right. It was hard to see with the side-by-side version.
The full comparison makes it more obvious -- especially when using the forum's before/after feature.
The instructions/code for using the before/after code is here: http://www.digitalfaq.com/forum/news...er-images.html
Is that banding (posterizing) in the on-screen shadow an error in the source footage? Or some other byproduct?
09-28-2012, 12:04 PM
Seems like posterizing is in the source. It can just and just be seen in the VHS dub too. The backround might be generated in post - I don't know the details of the production.
09-28-2012, 05:39 PM
robjv1 robjv1 is offline
Fun comparison!
I suppose though that it's not that hard to believe that we used to think some VHS tapes looked good. It's funny, after I've spent a few days working on VHS sources and not watching much TV, VHS starts to look really good to me, then I turn on an HD channel and it's like stepping into Oz lol.
09-28-2012, 10:13 PM
What causes that smearing on VHS anyway? (like to the right of the "Advance" text and D-pad) Its one thing that really annoys me about VHS sources and doesn't seem easy to fix.
10-06-2012, 01:07 PM
That's an interesting question. How much is due to recording and how much is added at playback? Do certain types of magnetic tape "bleed" over time in storage? My *guess* is that it's mostly due to sub-optimal electronics and video heads at the recording stage. Full white with quick transtion to dark - sub-optimal gear will not change the signal levels fast enough and there's signal residual which quickly fades away along the video head path, from left to right.
10-08-2012, 08:47 AM
The BVP4 proc amp can cause those, on some units, on some tapes. I've seen it here. It also varies between VCRs, even on the same tape. I think it's a combination of issues both on the tape, and with the hardware. It's the frequencies and oscillations, from what I understand.
Though obnoxious, it tends to be the least harmful issue. At some point, you have to just call it good and move on to the next tape.
Service Manual for Sony BVW-75P BetacamSP Editor (Serial No. 19747 and Higher) [DL] juhok Video Hardware Repair 3 12-27-2011 08:01 AM
Wanted: Sony BVW-75P BetacamSP editor manual jrpirola Video Hardware Repair 1 12-27-2011 07:47 AM
Service Manual for Sony PVW-2800P BetacamSP Editor (Serial No. 10001 and Higher) [DL] juhok Video Hardware Repair 2 02-23-2011 06:54 AM
