08-14-2005, 12:32 PM
I just picked up what appears to be one of the newest LiteOn units, the 5104, which has a (I believe) stereo tuner, AC3 audio encoding (a first from LiteOn), and supports DVD-R/-RW/+R/+RW/CD-R media.
I'm still getting that stupid hum from the tv tuner, but the s-video input quality is pretty good. I think it slightly lightens the picture (slight IRE error?), but it removes pretty much ALL noise from tapes. Grain, chroma, you name it... gone.
Great unit, if you need no tuner.
It is new and therefore in stock.
Was $180 on sale (until 24th this month) and also has a $50 rebate.
So not a bad little unit for $130 plus tax (about $140 in the end).
I'm still testing it. Because of all the S-VHS tapes I have with chroma noise, I want to keep it. But the slight lightening of video and lack of ability to use the tuner, not sure if it'll be a deal breaker or not.
08-14-2005, 02:10 PM
debwalsh debwalsh is offline
Where did you get the unit, LS?
08-14-2005, 02:20 PM
Got it at RADIO SHACK.
When playing back the recording, the "lightening" of video appears to not be happening. Appears only when recording.
08-14-2005, 03:32 PM
Pepeart Pepeart is offline
wich unit do you like better the LiteOn or the JVC?
08-14-2005, 04:00 PM
JVC. No contest.
08-14-2005, 04:06 PM
wich model JVC dr-m10s ?
08-14-2005, 04:24 PM
Any of them. But the non-HDD drives are the DR-M10S (discontinued model) and DR-M100S (current model). The 10 and 100 have few differences, mostly cosmetic and then new type of resistors so "loading" doesn't happen anymore.
08-18-2005, 12:13 PM
gatch72 gatch72 is offline
Send a message via AIM to gatch72 Send a message via Yahoo to gatch72
I got the same hum noise on my lite on 04 unit.
i hooked up a reciever to my stuff and it was gone.
it worked for me, try it that way if u can.
LiteOn (Ilo, Daytek, Gateway) DVD recorder hacks admin Video Hardware Repair 29 01-02-2020 02:34 PM
LiteOn DVD recorder hardware modifications admin Capture, Record, Transfer 1 03-05-2009 02:57 AM
DVD recorder repair service: Apex, Cyberhome, Digitrex, Liteon admin Capture, Record, Transfer 0 03-04-2009 08:29 PM
LiteOn DVD recorder for sale [SOLD] lordsmurf Marketplace 0 05-10-2006 08:00 PM
RAdio program to CD?? MagnificentMarcus Capture, Record, Transfer 4 07-28-2005 04:19 AM
