Go Back    Forum > Digital Video > Video Project Help > Author, Make Menus, Slideshows, Burn
03-14-2006, 11:47 PM
manthing manthing is offline
i did try looking around for help on this but couldn't quite find what i was looking for.
and since a couple of people here use ulead's dvdws, i thought i'd ask on this board.
basically, how do get auto chaptering done in dvdws?
now, i know there is one option, where the application runs through the entire mpeg and creates what it thinks is the appropriate bookmark/chapter points.
however, when i do this i end up with 64743237 chapters! okay so i exaggerated.
what i prefer is to have a bookmark/chapter, say every 3 minutes ala dvd lab pro where you can state the chapter time intervals.
is there a way to do this in dvdws?
03-15-2006, 12:33 AM
Yes.
- Go into the EDIT tab (top of screen).
- Now double click on your video in the assets "timeline" at the bottom of the screen. The video clip should now be in the main preview window. There is a slider bar under the video that you can move back and forth. There should also be an "add chapter" button (look for a + sign) directly right of the slider bar. Click on it to add a chapter at the nearest available I-frame (chapters can ONLY be added on I-frames on any DVD, even professional ones).
- Or you can do auto chapters every 3 minutes. Click on auto add chapters, and then select "by fixed interval" on the button drop-down. This is only available in the most updated DVDWS2 version, which is like 2.2 right now.
03-15-2006, 12:52 AM
Tcel93 Tcel93 is offline
The latest version is 2.232 which includes support for Dual-Layer burning. It looks like it hasn't been updated since 7/05
03-15-2006, 12:56 AM
ls - yes i did try method 1, ie moving the timeline and then adding the chapter. found this a bit cumbersome.
method 2 seems to be the one i wanted.
ta boyos. will try this when i get home.
Chapter marks in Ulead DVD Workshop 2 ? admin Author, Make Menus, Slideshows, Burn 0 10-04-2009 09:31 AM
DVD+R vs DVD-R (chapter marks) admin Blank Media 2 05-15-2009 09:50 PM
