Hi all,
I have several JVC HR-S9911U units and a JVC LP 20465-015 remote (bought separately). Unfortunately, I can't seem to get the VCRs to respond to the remote.
Video:
https://photos.app.goo.gl/5PVkgHzsbcGrvpPM8
The remote appears to be working fine (I see the IR emitter flashing through my cellphone camera).
A couple of months ago (before I got the remote), I was able to at least turn them on or off using an IR blaster with my phone, but now the VCRs are not responding to the IR blaster either.
The VCRs had been turned off for a while. They function just fine without the remote, but I would like to be able to access the menu (which I can only do with the remote).
Any ideas on how to get them to respond to the remote (or the IR blaster).
Thank you for any advice
