01-18-2021, 01:07 PM
zachrosing zachrosing is offline
Hi there,
I have a JVC S5400U that randomly stopped displaying color for any tapes in SLP mode. It otherwise is still working perfectly, and used to display color on SLP tapes just fine. I'm not sure what happened to suddenly make it stop, and no amount of cleaning I've been able to do has fixed the problem.
Any ideas what could have happened and if this is something I can fix?
Thanks!
Zach
02-01-2021, 11:07 PM
Offhand, no idea. Did you check out any of the JVC service manuals?
http://www.digitalfaq.com/forum/vcr-...r-manuals.html
02-14-2021, 05:31 PM
vilecr999 vilecr999 is offline
I had an issue like this on my Sony SLV-770HF
Only it was for ALL video output no matter what tape speed.
The issue was a set of surface-mounted capacitors on the video playback pre-amp board. Check that circuit on your VCR for any surface mounted caps and see if you can replace them. THat solved my issue!
Color streaks, washed out color on VHS? Roob2000 Capture, Record, Transfer 5 07-24-2020 06:37 AM
Is SP MODE the Best DVD Recorder Mode? (NO!) lordsmurf Capture, Record, Transfer 4 04-14-2013 10:01 PM
DV color space harmful to analog color quality? Verify? DeXeSs Capture, Record, Transfer 6 06-27-2010 01:48 AM
Panasonic FR mode or samsung 4 hr mode for vhs to dvd cyber-junkie Restore, Filter, Improve Quality 5 02-24-2010 10:29 PM
Encoding an XP (1 Hour Mode) MPEG to SP Mode shadowkaos Encode, Convert for discs 2 10-30-2007 09:29 AM
