07-26-2021, 04:04 PM
jonbang jonbang is offline
I have 2 pices of Panasonic NV-HS950-players. Superb machines, just to say that :-)
But now one of these has decided to not play any sound. I have tried many tapes, same result, those have sound on the other. I even had to retake about 14-15 tapes because of this, but thats a part of the game.
And because there are about noone in Norway that can fix these old players i have to ask.
Symptons piro to this was that sound was gone in some parts of the film, then i got a summing sound, just like ground-faulst in soundsystems.
I have tried to clean the heads with isopropanol/spirit/alcohol, no change. Oh, one change: the picture got a little better :-) :-)
But now i am stucked, where to start finding faults? I have been looking for bad capasitors, but didnt find any...
Help?
07-26-2021, 08:40 PM
Dougmc Dougmc is offline
We don't know your level of electronic repair .
Is the no audio coming out of the audio jack or rf tv antenna jack?
If it has both did u check audio on both?
Is the tape tracking on the audio head ok?
07-27-2021, 06:17 AM
There are no sound out from any place, and there are no indication on the display, where the meter for the sound is. No reaction there.
07-27-2021, 09:06 AM
timtape timtape is offline
There are two audio tracks in these machines, the linear track and the stereo hifi tracks. Can you switch between these?
If there is no audio on any track maybe the white and red audio output sockets have been damaged so that the internal connection has been broken.
07-27-2021, 07:27 PM
Try wiggling the connector to the head while playing.
Possible a crack circuit board.
Do a very good visual.
Possible capacitors, usually swells, or leak our of bottom.
Some small caps may not show any symptoms.
Maybe component may work by heating.
Try hair dryer. Don't get too much heat.
Usually I try heat and freeze mist to see if I can get components to act up.
Look at data on ics see if any have audio in or out ,use signal generator
And or scope to troubleshoot.
Getting sound using s-video out? BOBcat76 Capture, Record, Transfer 14 05-07-2020 12:17 PM
LG EC-330W has no sound? darko886 Video Hardware Repair 4 05-03-2020 06:50 PM
Panasonic NV FS100 - new caps, but no sound? inspiredron Video Hardware Repair 8 05-15-2017 07:24 AM
No sound on ATI All In Wonder capture? bbartley9 Capture, Record, Transfer 10 02-02-2013 02:03 PM
No sound in TMPGEnc Plus mlaviolette Capture, Record, Transfer 19 03-01-2010 03:25 PM
