02-24-2022, 10:28 AM
VHScollector19 VHScollector19 is offline
I have a nvhs860 model and the belt is old so looking for a replacement, I couldn't find a sizing guide anywhere for belts?
02-24-2022, 11:04 AM
Wagner suggests a 66mm (diameter), 2mm width would be a fit:
https://www.wagneronline.com.au/pana...-4405/1081/pd/
same with this australian site:
http://www.telespares.com.au/index.p...ucts_id=311582
Dönbarg redirects to 69mmx2mm square for the part number (which is the as used by 2000s LG, Samsung, Daewoo and probably other brands too):
https://www.donberg.ie/catalogue/vdv0382.html
Not sure which is correct.
The text on the donberg site, and the text on an official replacement part bag in this blog post about fixing a related japanese model with the z mech says "3mm" rather than 2 so maybe these sites just list the closest available (which may be fine.)
The same mech is used in a lot of cheaper models though, including NV-FJ, NV-SJ model plus the newer NV-SD and NV-HD models, and other panasonics from the late 90s to early 2000s so that may also be an option.
02-24-2022, 11:55 AM
Thanks I was struggling to find any accurate information.
Everything I was finding was contradictory, some measure circumference and some measure diameter and rarely state which is which so you might think you have found a belt by diameter and it could be the circumference.
I'll take a closer look, thanks again Hodgey!
11-08-2024, 08:33 AM
prodarek prodarek is offline
donberg now redirect to https://www.donberg.ie/descript/7/7118.htm
I'm completely confused about what size this belt(VDV0382) should be....
Why are Hi8 DV file sizes so large? Sac John Capture, Record, Transfer 30 06-28-2020 12:20 PM
Need a camcorder capstan belt Bullabill Video Hardware Repair 2 06-12-2017 04:23 AM
New file attachment sizes and formats for the forum! admin General Discussion 3 07-30-2015 11:55 PM
New sector sizes on hard drives? XP 512 vs 4kb? cyber-junkie Computers 7 05-19-2010 11:30 AM
Image sizes for menus? 720x480, etc admin Author, Make Menus, Slideshows, Burn 30 11-04-2009 11:19 AM
