  #41
06-26-2022, 01:30 PM
Quick thoughts.
- Cartoon releases were often given the lowest grade of tape. So it's still in play.
- If that 121 is markedly worse than the near sibling 120, then perhaps it is caps. Sometimes these errors must be seen in person, sample images and clips only go so far.
- Did I give you my email? If so, ping me. I'll hunt for your PMs later.
06-26-2022, 07:26 PM
pthebest19 pthebest19 is offline
I don't think you sent me my email yet.
There are a few VCR repair shops in Italy, I'll try to send it to one of them.
Anyway, WHV tapes were usually not low grade tapes. In Italy they started having hi-fi audio only from the late 80s, while in the UK for an example it happened earlier. MGM U/A tapes are really bad in Italy because they were outsourced to Panarecord (a local distribution) company, I use some of them to test the tracking. They did the same in Sweden with Esselte for an example.
Anyway my combo unit also came out the same year as the S VHS player, they even use the same remote layout (with a switch button to change to DVD IR codes). The reason why I wanted to upgrade to an S VHS player, other than the S Video output which isn't really relevant, is because the combos use an inferior control track head, trying to rip hi-fi audio or certain tapes becomes a nightmare.
noise, panasonic, s-vhs
FixRips grain noise dropouts (tweaked version) script? themaster1 Restore, Filter, Improve Quality 10 06-16-2022 01:29 AM
Panasonic NV-HS960 strange noise prodarek Video Hardware Repair 0 05-29-2022 03:20 PM
Panasonic 1980P noise patterns? Qaenos Capture, Record, Transfer 31 01-19-2021 06:27 AM
Cartoon restoration project - film grain noise removal? via Email or PM Restore, Filter, Improve Quality 1 07-26-2014 11:39 AM
Can't remove video noise/artifacting (grain in dark areas?)) DeeSeven Restore, Filter, Improve Quality 8 07-23-2014 08:19 AM
