11-20-2022, 09:19 AM
MrPete MrPete is offline
I honestly know better but didn't do it: didn't take photos as I tore into my K-chassis Panasonic. (Mine is AG-5710, vanishingly similar to AG-1980)
All I have left for reassembly is top/bottom cover and the two layers of front panel (Front Panel, Sub-Front Panel)
The four screws for the top are easy.
The other three:
* Seven (eight in my case) screws for the bottom panel
* One screw top-center for the front panel
* Four screws (left/right/2 center) for the front sub-panel
I have 9 brass screws, 2 large red, 2 small red. I don't want to mess anything up.
My guess: brass are for the bottom and top-center of front panel
But the four red... not obvious which holes take large and small.
Anybody simply know?
Solved it.
* Center of sub-front uses the two larger red screws
* Outer sub-front uses the two smaller red screws
* Top-center of Front, and bottom panel, use the rest
* (AG-5710 has an 8th bottom screw, center-back of the panel)
11-20-2022, 03:59 PM
When I work on something for the first time I put all screws in small bags and label them with sharpie, I also put the screws back on place after removing the part whenever I can so I don't have to guess later, I learned that the hard way few years ago when I dismantled a Toshiba Satellite series laptop, they used at least 15 screw types in length and shape, pretty strange.
11-20-2022, 05:36 PM
Originally Posted by latreche34 View Post
When I work on something for the first time I put all screws in small bags and label them with sharpie, I also put the screws back on place after removing the part...
Exactly. I've done deep repairs on DSLR's, laptops and much more... I either use bags or a tray with lots of slots.
Truly dumb to just start dismantling.
11-20-2022, 07:36 PM
Don't feel bad, we all do it.
In fact, I've done it with an AG-1980 myself. Even with putting the screws in medicine bottles to separate, due to a time lag between starting and finishing, I no longer knew what was what.
Extra parts are good, right?
For sale AG-1980 VTR davidparks Marketplace 1 06-27-2021 08:47 PM
Where can I get new belts for AG-1980? digicube Video Hardware Repair 2 06-18-2020 06:59 PM
AVT-8710 vs. AG 1980 VCR and TBC? jcdifi26 General Discussion 3 04-23-2017 07:47 PM
Subtitles placement on Blu-ray, Adobe Encore? jrodefeld Encode, Convert for discs 4 08-26-2016 09:59 AM
Looking for a Panasonic AG 1980(P)? Duberg Marketplace 1 03-04-2013 03:15 PM
