01-29-2023, 11:09 PM
FishonDavid FishonDavid is offline
I have been struggling with this squealing during tape eject, on my AG1980, and only when my VCR is in the horizontal position, and only in the eject mode, no squeal during FF or RW, only during eject, i made a short video, to show you,
the funny thing is, as you will see in the short video, that when i set the VCR on its side, and eject a tape, , the squeal goes away,(or does not appear) but in the normal horizontal position it returns, can anyone tell me, which parts may need replaced or lubricated to stop this horrid sound? thanks in advance if anyone has some suggestions
02-11-2023, 01:53 PM
AG-1980 decks make so many noises. Yes, it's obnoxious at times. The issue with squealing isn't always lube, but the pulleys for bands.
Please don't be stupid and squirt WD-40 inside. Somebody at this forum did that years ago, screwed his deck up, got it on the heads. It's a VCR, not a bike chain.
The following users thank lordsmurf for this useful post: FishonDavid (02-12-2023)
02-11-2023, 10:02 PM
timtape timtape is offline
I'm not familiar with this mechanism. It could be a slipping rubber belt but sounds more like a worn/dry bearing in the mechanism controlling pinch roller, brakes and maybe cassette eject.
Operating the deck horizontally does reduce the load on the cassette eject mechanism as there's not the weight of the cassette to lift. But interestingly the noise seems to start even before the cassette is ejected so not sure why that is.
The following users thank timtape for this useful post: FishonDavid (02-12-2023)
02-20-2023, 08:10 AM
2ylite 2ylite is offline
I recently picked up an AG-1980, which appears to have been sitting for a while, and I also noticed this sound squealing sound. Like others, I too thought maybe there was something that needed lubrication, but now I'm not so sure. I'm stuck.
Eject malfunctioning in JVC HR-S9600? Tokyo_DIY Video Hardware Repair 27 05-29-2025 05:30 PM
JVC HR-S6900U squeal, static? Darkmatter General Discussion 1 05-19-2022 04:30 AM
Panasonic AG 1980 wont eject tape. waloshin Video Hardware Repair 8 05-14-2020 02:27 PM
VCR won't load nor eject cassettes? meeshu Video Hardware Repair 5 01-31-2020 11:33 PM
NV-HS1000 won't eject tapes Medusaman Video Hardware Repair 3 03-12-2013 03:10 AM
