06-03-2024, 09:42 PM
MrPete MrPete is offline
Sigh. One of the front panel switches (Auto/Normal/Wide) has the "stick" breaking in half. Not fully busted but close.
  • These are hard black plastic. Anybody know what kind it is?
  • Has anyone attempted and/or succeeded in repairing one of these switches?
  • (On these Pan SVHS players, it's SW48)
While I'm at it, what IS "Wide" vs "Normal" format? I've not found a description anywhere...
06-05-2024, 05:22 PM
aramkolt aramkolt is offline
Guessing wide relates to widescreen or similar. If it was me, I'd probably file down the long switch pole so it is flat wherever that is on the stick and then just move it with a longer object if needed, but this is a switch that will almost never be touched, so I don't think it really matters.
If you want it to be all original, I can probably scavenge an original switch from a parts AG1980 unit and send it to you for $15 shipped within the USA - if interested, PM me.
06-06-2024, 03:01 PM
Thanks, @aramkolt! Meanwhile, I have learned a few things and taken action:
- It's called a "splash cap" and many slide switches allow a variety of these when specifying the switch (Not easily found for this switch though)
- It's made of 6/6 Nylon aka Nylon 6 aka Polyamide 6 aka PA 6 (plastic)
- I'm waiting for the glue to dry on a repair job:
* Clean with Isopropyl Alcohol
- Use appropriate glue. I'm using Loctite Extreme Gel that I had on hand
(For this glue: clean, dampen slightly, use a pin to put on one side of the crack, wait 5 minutes, clamp shut, wait at least 2 hours or 24 for full strength.)
Here's hoping it works!
And yes, I am guessing that "auto" position is likely all I ever need.
Panasonic AG-1980 AG-5710 capacitor mystery? MrPete Video Hardware Repair 7 01-16-2026 12:13 AM
Link to AG-5710 and AG-1980 VCR sales sheet jwillis84 Video Hardware Repair 2 09-23-2017 03:27 AM
Panasonic AG-1980 Mode Switch Repair flaviotoribio Video Hardware Repair 2 05-03-2017 11:12 AM
Is the Panasonic AG-1980 or AG-5710 still worth it? waloshin Capture, Record, Transfer 21 07-28-2016 08:45 PM
Panasonic AG-5710 (AG-1980) can play VHS-C as 16x9? Jpass992 Capture, Record, Transfer 1 08-05-2012 11:39 AM
